Advice needed, CPU getting hot.
Saibolasi
Hi Guy,
Recently i replace my stock cpu cooler to cooler master 212X.
But when running Witcher 3 game, my CPU seem to be quite hot temperature staying between 68°C to 72°C. Is that consider normal?
game running on i7-4770, 16gb ram with gtx 1060 6gb.
SkyShroud
It is normal, your cooler likely not running at max speed, no reason to either.
If you want it to go lower, you need to manual set it to max speed or get a premium cooler.
tsteo77
It's not normal for me, I using 212led cpu cooler and my heatsink not even warm after hours of usage / gaming. But i using fuse less power cord.
SkyShroud
need to account for casing as well
thats a one in one out case
if 2 in the temp will drop a bit more
Saibolasi
Stock cooler temperature at about 60°C - 65°C(max) for other game like Dragon quest heroes 2.
So far CPU fan control is auto. As for my case fan, I have 2 intake and 1 exhaust fan.
My CPU only heat up to 70°C+ when running witcher 3 (not on max setting, capped at 30fps)
Rashkae
Each game will tax a CPU differently, so you can't compare.
68-72 is normal for Intel.
SkyShroud
yea...do a apple to apple comparison
dont compare diff games = =
easiest way to compare is just do a burn test for 10min
Saibolasi
Thanks for the all advice.
I will try the burn test.
Just afraid that i might install the cpu cooler wrongly as my old stock cpu cooler was dead.
thanks for the link for the linustechtips.
StationA
use the Stress CPU function on cpu-z can push the CPU to top. (in the Bench tab of cpu-z)
Saibolasi
By the way, if i run the burn test or cpu-z stress test, will it damage the cpu?
After all, this i7-4770 is an old model(mobo also old model). I don't think able to find and replace if damage due to overheat :s11:
P R N D
212 is a good cooler.
I using 212evo reduced my i5 4460 from 50℃ to 40℃
Suggest you reinstall your cooler again.
Sent from Mercedes-Benz E250 using GAGT
StationA
in my memory only old CPUs may get damaged during auto freq/voltage settings. nowadays the CPU all can protect themselves by slow down if too hot. but yes the possibility still exist, but, as you know you are stress testing the CPU, cant you watch the temperature readings and stop it by your own hand if the temperature goes above 80 degree? :eek:
Saibolasi
After in the 212x cooler, my cpu did reduced when idle.
The temperature will only shoot up when playing witcher 3.
Will check again for the cooler again.
Saibolasi
kind of afraid as i didn't run cpu stress run before.:s13:
manXeater
Did you remove the sticker on the new cooler? Sounds stupid, but I've seen it happening quite a few times
Sent from Samsung SM-G975F using GAGT
hlots123
are u capping 30fps using witcher3's ingame option? i rem this may cause high cpu temps
try set back to unlimited to test if cpu temps improve - if improve, then cap using other method like rtss instead of in-game
