Which memory for Ryzen?
FD Trinitron
Found the below 2:
1. G.Skill Trident Z RGB 3200Mhz C16 16Gb x2 - $309
2. G.Skill Trident Z NEO 3600Mhz C18 16Gb x2 - $319
Price difference only $10, which one is more recommended?
SkyShroud
As above, both are the same.
Simple math is...
3200 / 16 = 2
3600 / 18 = 2
Higher the better, for this case both are same.
wwenze
Simple math is...
3200 / 16 = 2
3600 / 18 = 2
If same why they sell 3600 / 18 more expensive than 3200 / 16 :s13:
robolee
Simple math is...
3200 / 16 = 2
3600 / 18 = 2
that is just base on "latency" not Bandwidth.
if you got money to throw just go 3600 cl18 although there are better offer i think on amazon
SkyShroud
becoz the difference, most layman won't understand
ram timing doesn't has just one number but 5 different numbers which usually you only told the first 4
so if u really want a real comparison
u need compare all the ram timings and not just the latency timing
FD Trinitron
Thanks all for the replies, think will get the NEO model since G.Skill stated its optimized for AMD Ryzen.
StationA
100$ extra for the bling bling ARGB... :eek: newegg has Ballistix Sport LT 32GB (2 x 16GB) 3200Mhz CL16 for sale about 230$ only. and I enabled xmp get it easily run at 3600Mhz CL16.
StationA
isnt 32gb overkill ? even games never utilize so much ?
yes agree. I never see my machine memory usage over 16GB, unless run the memory stress testing use Prime95. if choose again, I would take 8GBx2 memory and spend the saved 100$ for bigger SSD.
robolee
i spent $228 on the same ram over at amazon :s12:.
i presume u must be using ryzen 3000 series cuz for my 2600 increase higher than 3200 = BSOD
32GB has it's use when u are multi-tasking while playing and i am 1 of % that require 32GB to maintain smoothness while multi-tasking. If you are just gaming nia then of course 16GB is enough
FD Trinitron
Just notice the G.Skill Trident Z 3200Mhz has the NEO model, price wise is very very close to the 3600Mhz.
32Gb kit
G.Skill Trident Z 3200Mhz NEO C16 - $315
G.Skill Trident Z 3600Mhz NEO C18 - $319
Back to same question, which one better? :s11:
Koenig168
32Gb kit
same :s12:
swathe
While RAM price is low, I would take the opportunity to go for 32GB if I can afford the $100. It will not be $100 when you want to upgrade a few years later.
2-3 years ago, people thought 8 GB was the sweet spot.
wwenze
2-3 years ago I was already complaining 8GB no enough...
Definitely going 32GB for my next build
Koenig168
few years later, we will be on DDR5 :)
that said, makes sense to pick up another 16GB when it is so cheap now
