The Casual Bag Thread
indigo22
Mine is diameter 2 inches.
Thanks for the ideas however dont think i will go that route. Still considering how to secure it. Only incomplete method so far can come up with is to somehow secure it using the front hidden webbing.
ya cuz i've never seen anyone doing DIY sewing on VX material before. so the best (and the ones which i recommended) is actually to hook on the front hidden webbings de :D
nez
I wouldn’t dare to “poke” any holes (even tiny holes like sewing needle) into the bag material 😂
chromehead
Is the granville zip16 really 20L ish? I scared too small...
Considering granville 20, went campers corner today, and they have both old version (with magnetic flips and large compartment opening) at $350, and new version (with zippered flip which makes opening smaller) at $300.
Which granville will you get?
16 looks good and slick to me. not too big = wont really worry about overloading it.
one ez way to gauge would be say your usual laptop or books, then see if can fit your exercise clothes, shoes and toiletries in.... 16L may be a stretch
never really liked the big foldover flap thingy look, but flap closure = can have capacity to overexpand, just lash down the flap.
moooze
does anyone have experience order from the "The Leather Satchel Co" before?
looking to get one 14inch satchel for work but its around 360~380sgd so looking for opinions.
any stores that sells leather satchels locally?
thanks in advance!
Basilchristeo
The 16 can definitely hold about 20L if you get creative with your packing...like I posted previously I could fit shoes, clothes, tech pouches, toiletries & a water bottle into it.
If you're worried, why not bring your usual EDC to campers corner and test out fitting your stuff into both bags? I recommend the Novena outlet as it's open on Sundays and is usually not as crowded compared to the main outlet.
Basilchristeo
Just to add to my earlier, I managed to squeeze the following items into my Granville Zip last night, the front pocket actually can hold a ton of items:
  1. A pair of bball high tops
  2. A change of gym clothes
  3. A dopp kit for toiletries
  4. An umbrella & a water bottle
  5. 3 resistance bands (front pocket)
  6. 1 hoodie (front pocket)
  7. 2 tech pouches (1 pouch in the front pocket, the other in the top pocket)
  8. 13 inch MBA
furryballs
  8. 13 inch MBA
Thanks!! I just bought a zip 16!!! Enjoying the bag for ages days already. Zip initially Abit stiff but it is breaking in
indigo22
just to manage expectations, the zips will continue to be stiffer den your usual bags because it is a water-resistant zip
magna_strike
Henabi
Tbh, i used to be interested in tom bihn bags and wanted to get one for their many pockets and ways to pack, but from the outside, really look like my marketplace those 10-20 dollar cheapo brand bags sia..
I am so agree with you!
Sent from Henabi virus using GAGT
Spladox
lol ikr? I tried my friends' s25 and it was really comfortable. but the looks is really cmi. gonna hoot axiom 18/24 soon. have to go down to try but leaning towards 18 cos the price difference pretty huge.
nez
A couple of questions for axiom 18/24 users
- does the paint, on the metal zipper, chip off after some time? (I notice my previous citadel does)
- I notice white marking (like chalk marks) along the zipper covering. What you use to remove them? I previously use wet tissue & the whiteness remains. Nothing major but would love to see if can remove.
indigo22
- paint? if u mean the color of the material, then mine doesnt. usage for 1 year plus le.
- i always manage to wipe it clean with a wet cloth.
nez
I regarding the black paint on the metal zipper :D
Spladox
- does the paint chip off after some time? (I notice my previous citadel does)
I don't own one but I read that vx21 is a material that doesn't do well against abrasion but it's lightweight and extremely water resistant.
nez
Roger that. Thanks. To clarify, for the paint I referring to the metal zipper. As for the white patch ( that looks like chalk marks), so far affected area I have noticed is more so on the hypalon material near the zipper.
