Xiaomi MIPAD 4
kottty
Sorry all these terms are kinda Greek to me. Can you point me to some reading materials on volte? Also, I am phobia of bricking a new tablet. If things go wrong I won't know what to do. Is there a step by step guide to Havoc OS? Thank you.
volte is for u to make call with 4g signal..if u no intend to making call using this tablet den is OK,just use MIUI ROM
Sent from Xiaomi MI PAD 4 using GAGT
RockingHorse
Hi experts,
I am keen in Mipad 4 due to the good reviews but I am a noob and would rather not root the device or change the OS. A few questions:
1. If I buy from Qoo10 and Lazada sellers, only Chinese ROM right?
2. If I don't change the default ROM, can I log in my Google account and use all the Google services and download apps from Google Play Store?
3. If yes, any simple step-by-step instructions online?
Thank you.
If you don't root, you can't use the GPS, made phone call and etc.
Rustify
Would it be advisable to root it if I am just getting the 3/32gb wifi version? Is the 32gb an issue? Since there is a micro sd slot. I planning of using it for gaming like those 5v5 games. Serving the net, watch videos and as a planner maybe. Is it smooth like using an iPhone?
SibehHL
If you need gps do note that the wifi version does not have it
PES1989
Sometimes the face recognition unlock don't work, tried pattern unlock also same problem, have to reboot device in order to solve the problem. Anyone else with the same issue?
Sent from Champions of Europe using GAGT
Just Me
The face recognition on the mipad 4 is not secure as compared to their phone counterparts. Don't use it as your main security
Sent from Xiaomi MI MAX 3 using GAGT
bran36
Bought a Mipad 4 a week ago, just got permission to unlock bootloader, than flashed custom rom with gapps. Using Havoc now. Don’t really like it leh, might reflash back to MiUi. I’m an iOS user, maybe that’s why. Anyone using custom rom? Can recommend?
allanzzz
yes, had this sometimes.
using EU rom.
still no idea why, but very rare that it will happen.
bran36
no problem. much much better than Havoc or any others, and i was on havoc before :)
just read instructions well and you're good
I flashed the kernel and the custom rom by the same author, late last night.
Compared to flashing Havoc, this was more of a hassle. In fact I tried three times to get it fully working, the first time couldn’t get his TWRP flashed, used another TWRP to fully wipe device first, than second try, I forgot to flash my Nano Gapps, but didn’t install TWRP after flashing rom, so I decided to redo everything. Third time the charm!
But dam, well worth the effort! Very smooth and good battery consumption, am on the 8” LTE version, no bugs so far, fully working. Is this what they call the “stock” android experience? 😂 thank you once again! In the future I got more android devices, this guy’s roms will be definitely top of my list.
imacbie
glad u like it.
as near to stock as possible is always good, and light
well close to stock at least.. its on PA which is based of aosp.
guy doesnt usually do OS, he's more into kernel stuffs :)
hellhole
wtf?!?!? so easy to install havoc meh!??! i still stuck at adb install and twrp!>!>!?!? haha
