See the settings for notification light is switched on?
Yea same. I think I only get the light for system app notificationssame same in fact i dun see lights for all the notifications
No one?.....
Yea it's not very useful anyway. Can try always on display but it doesn't work for every app.dun quite like the location of the notification light. is at the pop up camera there. v hard to see
I think the top end model for the pro will cost at least 150-200 more than k20pro 8/256
Sent from Xiaomi MI MAX 3 using GAGT
Erm, not an expert on this but... m9t pro got diff with k20 pro?
Global rom, more European network bands and the ability to stream Netflix in hd.Erm, not an expert on this but... m9t pro got diff with k20 pro?
Probably even more. Just look at the released pricing in europe... And might not even have the 256gb variant.
https://www.gizmochina.com/2019/08/...dc04voKQEqt3hzFIjUD9_DsxLFDP-944tItWRx7h2X1Dw
*Mi 9T Pro with 8GB+256GB is only availible in Hong Kong, Taiwan and Indonesia, whereas Mi 9T Pro is only available up to 6GB+128GB in other regions
what improvement (UI smoother?) do you get with modding the screen refresh rate to 81 Hz? do you also see any glitches with other apps...?
ya it will feel much smoother than normal 60hz, however battery endurance may take a hit, and it's not certain whether it may cause permanent hardware damage, so try at your own risk.
