Xiaomi Android TV Box discussion II [consolidated]
Charlie_Zhan
Any good air mouse to use with mibox s? Anyone can share your experience?
not really considered air mouse but I have a Logitech k830 htpc keyboard+trackpad combo. but most of the time default control is good enough.
Elon Jobs
Buying a Mi Box myself, just want to double check with you experts here before I pull the trigger. You guys are recommending this box right?
Check out Xiaomi Mi TV Box 3 Android 6.0 Smart 4K Quad Core HD WiFi Bluetooth Box at 16% off! $74.76 only. Get it on Shopee now! https://shopee.sg/product/70777863/1273287201?smtt=0.0.9
And not this?
Check out Xiaomi TV BOX S Global Version (with Play Store) at 38% off! $79.90 only. Get it on Shopee now! https://shopee.sg/product/1058775/489727928?smtt=0.0.9
gregory_choo
And not this?
both are ok, except the price.
this is better, only $60
https://www.lazada.sg/products/xiao...-smart-4k-hd-tvbox-i270828673-s527122869.html
Elon Jobs
mibox S is newer but has lower soc clockspeed and unable to support HD audio passthrough.
Thanks for the link- didn’t know it was that much cheaper on Lazada. Will buy that then.
So am I right to say that basically, Xiaomi launched the Mi Box S but actually there’s no improvement on it besides the newer shell on the outside?
Charlie_Zhan
unless you consider android 8.1 vs 8.0 to be an improvement, then yes the mibox S has that 0.1 improvement. :s13:
HuatKway
I got the mi box 4 from China. Don't suppose it's useful? :( Realised only after I got it.
It can't detect my 5ghz signal and of course it's in Chinese. No international rom available for flash I suppose?
Charlie_Zhan
can use as paperweight..
gregory_choo
go to your router and change the wifi channel. mibox can only work with lower channel numbers in the 5GHz band.
ignore the pre-installed apps because most of them are locked in china.
you can install other better apps.
HuatKway
I tried that actually. Lower to channel 60 but still didn't get to work sadly
boonkang
If I'm not wrong,
Mi Box 4 for China market -- don't support 5Ghz WiFi, only supports 2.4Ghz WiFi.
There are 2 models of Mi Box 4 for China market:
(1) MDZ-20-AA: 1GB+8GB (Black, Mi Box 4C)
(2) MDZ-21-AA: 2GB+8GB (White, Mi Box 4)
If you're using either model above, I think don't bother changing 5Ghz WiFi channel on your router -- both models don't support 5Ghz WiFi at all.
You can check the specs for above models of Mi Box 4 for China market on Xiaomi Website at this link:
https://www.mi.com/mibox4/specs/
You can also check specs for previous Mi Box 3 series models for China market on Xiaomi Website at this link:
https://www.mi.com/hezi3/specs/
As you can see from above 2 links -- under the item 'WIFI':
For Mi Box 3 series -- stated as "双频 2.4GHz/5GHz,802.11a/b/g/n/ac" (so 5Ghz WiFi is supported)
For Mi Box 4 series -- stated ONLY as "802.11b/g/n、2.4GHz" (so 5Ghz WiFi is NOT SUPPORTED)
If you wanted to use 5Ghz WiFi, then you should have easily checked Mi Box 4 specs using the above link BEFORE buying.
I think people just assume that all models of Mi Box 4 series support 5Ghz WiFi -- because (previous) models of Mi Box 3 series for China market all supported 5Ghz WiFi.
Don't ask me -- why previous models of Mi Box 3 series for China market all support 5Ghz WiFi -- yet newer Mi Box 4 series for China market don't support 5Ghz WiFi.
I don't know why -- go ask Xiaomi :)
Of course above are just Mi Box models for China market.
There are also Mi Box models for overseas market -- which many people in this thread are using:
MDZ-16-AB: Mi Box 3 International Edition, 2GB+8GB, upgradeable to Android TV OS 8.0
MDZ-22-AB: Mi Box S, 2GB+8GB, Android TV OS 8.1 (which logically speaking, is Mi Box 4 international edition)
You can check specs for MDZ-16-AB at this link:
https://www.mi.com/global/mibox/
You can check specs for MDZ-22-AB at this link:
https://www.mi.com/us/mi-box-s/specs/
Yes, both MDZ-16-AB & MDZ-22-AB support 5Ghz WiFi :)
