HD as in 720p?Thanks for the post. I assume 2.4ghz is enough to stream normal movies up till HD ?
Thanks so wif this setup I’ll b able 2 enjoi hdr n hd audio right? Hope there wouldn’t b sound sync issue...only Kodi
be more specific.. what app are you referring to?Can you watch Taiwanese and korean shows with the Mi Box S?
go read up what is android tv osI’m not sure what apps are there but are there any on the Mi Box S that have these programmes?
If you're referring to mibox s, just have to install the vpn app that you want from google play store just like any other app.So meaning I get a mibox inside the store I can do a VPN app right if so I gg get it ... the only problem I face is only the VPN stuff
Mibox S tv box is like a new android phone without additional apps.I’m not sure what apps are there but are there any on the Mi Box S that have these programmes?
My mi box 3 just went kaput. I'm thinking of switching to fire stick 4k (my mi box was always lagging and just not up to par when playing 4k videos) or should I get a mi box s instead
Sorry, don’t mind me asking- how long you used it for? What happened?
I think I had it for almost 2 years and I normally use it for YouTube, Netflix and some other streaming services. I'm not sure what happened but it seems like it just died
download x explorer from the tv os play store.
sent you a pm.. should be useful for you.Thanks, it worked! Appreciate it. Just finished setting it up.
