Redmi K20 Series - The Redmi flagship
razorlala
y i see ppl saying china rom has so much cost saving and is almost the same but this thread is filled with ppl with china rom issues?
richneo
I am on 10.3.16 but still unable to add my dbs visa. Fails after contacting bank
I suspect got something to do about unlocking bootloader to flash other rom with SQL and gpay fix and then flashing back China rom and locking bootloader with miflash recovery rom
Nakedtoes
my screen shot
quite be the bank side issue.. i later add my amex to try.. so u unlock bootloader and lock back then can add visa? but seriously i dun mind... i use mastercard most of the time... most of my card also mastercard
Nakedtoes
u ownself said almost then what do u expect? Some ppl dun need nfc they get indian set.. some ppl dun need L1 windvine they get china set.... some ppl dun mind slower update, less features and more expensive set they get local set.
Soulfly
They do. They launched in Hong Kong and Taiwan.
Singapore Xiaomi always like to bring in the lower end model
Thanks for the reply. Guess I'll be checking out the Hong Kong Mi9T Pro with 8gb/256gb model...
richneo
i unlocked and installed eu firmware with sql and gpay fix and then i flashed the eu global rom. didnt like it and flashed back to china rom and locked bootloader
in both eu and global rom, i have added cards into gpay and used cardless payment in ntuc and transport before
YongTauFooo
How do you get contactless payment to work on EU? I can add my card but can't set up contactless pay cos it said "my phone is altered or rooted" even though I did not root my phone
naxchua
I just flashed China rom recovery with miflash tool and locked my bootloader
Tried adding all my Visa, amex, master card to google pay and all works
Bro, so u still using China ROM right?
ccloh
Just Me
for those looking to buy the Mi9T Pro cheap, there is something i found from Aliexpress but the configuration a bit the weird. 8G/128G global ROM version and cost $552.71 exclude voucher discount and shipping cost ($15.85). there is also the 8G/256G model cost $662.69 base price
https://www.aliexpress.com/item/330...chweb0_0,searchweb201602_3,searchweb201603_52
You forgot the gst
Sent from Xiaomi MI MAX 3 using GAGT
faithsilence
so can anyone share which is the best place to get a local set 128GB set? Shoppee? Lazada? Thank you
richneo
Google for SQL and Google pay k20 pro fix.
It has been posted in earlier pages of this thread too
Reavl
is there any reason why you dont like eu global rom and did you try the mi9t pro rom?
Thanks
