Redmi Note 8
garychengjw
  1. Mobile Phone with Bluetooth and Wifi Redmi M1908C3IG XIAOMI
  2. Mobile Phone with Bluetooth and Wifi Redmi M1908C3JG XIAOMI
  3. Mobile Phone with Bluetooth and Wifi Redmi M1908C3KG XIAOMI
  4. Mobile Phone with Bluetooth, Wifi and NFC XIAOMI M1904F3BG XIAOMI
so many new models, only one has nfc
which one:s11:
The one with NFC could be A3 Pro or Mi 9 Lite, the rest looks like Redmi 8 series lineup.
xonix
Strong possibility...
https://www.gizmochina.com/2019/08/09/xiaomi-m1904f3bg-cc9-gets-certified-in-russia-may-launch-soon-as-the-mi-a3-pro/
kazuki666
UFC should be only Pro version? SGD400+?
Sent from Xiaomi POCOPHONE F1 using GAGT
alex22
UFC ? No free canned fruit when buying the RMN8PRO lor. lol
NightRaven49
Faint bad typo. I meant ufs 2.1... Haha
But I feel it's weird they use mediatek for pro, non pro use SD...
ya but u see the g90 is actually faster than the best sd premium midranger, some more the sd 665 on the non pro is just a rehash of the old 660. so it kind of makes sense to put a faster chip on the pro variant. whether other issues will pop up like battery life remains to be seen though.
Jun Kid328
Actually the main problem with the Redmi Note 8 Pro is heat. The Mediatek G90T is significantly faster than the best sd midranger but comes at a cost. The G90T runs significantly hotter due to its higher clock speed, especially the GPU. Even with the copper heat pipe inside, it still heats up rather often. Its hot, but still acceptable. Though battery lofe would be interesting in the long run though, since the MTK chipset is manufactured on 12nm process compared to 8 on sd 730, so power efficiency would be affected.
