Xiaomi mi pad 4
taxiphv
I saw this on a seller page on Qoo10.
"LTE version does not support phone call function."
Is it correct? Mi Pad 4 doesn't have a version which supports both mobile data and phone call?
PES1989
Your Miui must be before Miui 10, Kotty can guide u on this.
Sent from Champions of Europe using GAGT
Teo Ming Ern
Calls over LTE network (VoLTE) works but not the standard voice call.
meekiatah
Which shop sell screen protector for Mipad 4 and help you to install?
SLS level 4 should have 2 shops (related) that sell TGSP and cases. One of the shop is at the corner nearest to the escalator. Last time, I bought for my MiPad and SP4. They specialise in TGSP, skins and cases.
Posted from PCWX using
Where Does My QR Code Goes To?
really_noob
Thanks. I'll go and check it out. Do you know how much?
I asked at a shop at Parkway, tempered glass $28!! Might as well buy 50 pieces from taobao and do it myself trial and error.
The JB shops don't have, understandably so since Xiaomi doesn't sell this model globally.
meekiatah
Don't recall how much. But, it's not cheap like the $8-$10 that you get for hp TGSP. Buying from Taobao / Aliexpress might be a better choice for you than making a wasted trip to SLS.
Actually, isn't TGSP easier to apply than those film ones from yesteryears? I have been doing it myself for my phones.
hkchew03
but only when u are streaming it right? how about when u download the shows?
Mipad4 only have widevine let, only up to SD in Netflix. Mipad only stream/download Netflix at 540p, quarter of its resolution for better scaling.
Posted from PCWX using Redmi K20 Pro
