The Spectacles Thread. - Part 2
Hi all! I'm looking to make a cheap pair of prescription sunglasses for travelling as I don't like to wear contact lenses. How much would a cheap frame + polarised lens cost? Owndays quoted me $276. Not sure if that is the cheapest already. Also, how much would a mirror coating cost? My degree is 400 left eye and 600 right eye. TIA!
Hi bro,
Another way is to use clip-ons glasses
3 Different polarized clips: Yellow, Grey, Grey mirror
JOEL9978
Hi Guys,
Is it a must to make progressive lens above aged 40?
I'm turning 41, looking for recommendations on lenses and optical shops.
my degree is around 4.75 and will be using my frame.
Lens wise not too expensive.....
TIA
Hi Guys,
TIA
Progressive lenses is optional. Would be recommended if you start having difficulties viewing at near. If near is still quite ok, then its not a "must" but a "good-to-have".
JOEL9978
Hi Bro, any brands to recommend?
And roughly how much is normal and progressive price for my degree.
Don’t need frame.
striker22
Depending on the size, your frame may not be suitable for progressive lens. U need to check with your optician.
juxtaposition
Got a quote for hi-index 1.6 lens
CRIZAL TRANSITIONS® XTRACTIVE $440
What do u think?
What do u think?
Price looks good.
If you require Blue Absorb as well, can consider Asahi Lite UV3G Sunfilter/ Kodak Evoblue
Turns dark under the sun and filters out 94% HEV light too.
:s12:
Buckbrick
Anyone can recommend a reasonably priced progressive lens for home use? Thanks
GANGSTERKIA
Does typical spectacles shop sell prescribed swimming goggles with degrees?
Yes, some do. However it does not come with astig correction and if the power of both eyes are different, you might need to purchase 2 to swap the lenses to balance out the power.
However usually when swimming you dont need full sharpness clarity thus you usually need something lower. e.g. -2.00 just take a -1.50 goggles will do the job well.
leongheng70
Zeiss Precision Plus
Hi looking for another alternative to Zeiss Precision Plus as need to make a pair of progressive as current need to change, any recommendation, prefer to be ard $600 or less, need the following (on tight budget)
- Transitions
- Blue control
- Frame include if possible
4D.TOTO&BS
My Varilux Physio 3 progressive is super discomfort. Desk bound is merely acceptable but outdoor is terrible especially night vision is blurry.
What other options could I get for good outdoor and night vision with progressive lenses?
- Transitions
- Blue control
Hi bro, what's your degree like?
Look out for 4k Varios Premium Transition Nano Blue by Mvision.
Performance is similar to Zeiss ID 2 but much more affordable. If degree is not too high, a 1.50 index version with transition would be within your budget.
