lorettatay
- Feb 10, 2001
I want the box leh!
Then no choice haha
Posted from PCWX using LYA-L29
I want the box leh!
Then no choice haha
If bo bian and it’s way cheaper than sg, then guess I’ll debox.
Definitely cheaper in sg
You know the sg price yet? Dunno where I read but may be the around the MF price range.
yes that is correct $1100
Millennium Falcon or Imperial Star Destroyer
If you only have to buy and keep one, which would it be and why?
The issue is the scale of the set. I do not have the luxury of space to display both. Maybe I should just sell off my MF.The answer is both. You can sell hair, sperm, kidney, liver, blood or skin
I will say MF is the better choice for display.. it is definitely the coolest and fastest spaceship in the galaxy!
I will still get the ISD though.. just wondering where can I put after building...………..
