iPhone 11/11 Pro Accessories Show Case Thread
ragnarok95
Senior Moderator
Senior Moderator
Same as always. Do NOT try to sell your products here. Infraction will be issue. :D
ragnarok95
Senior Moderator
Senior Moderator
IF you know a supplier is trying to sell here, let us know too.
Also, NO ADVERT here.
disastrous
The screen looks the same as the XS Max's dimensions?
Means we can use back the same protectors on the display?
athenodorus
$59 for a transparent case at Apple store. Sounds like a scam.
Might just get the pine green silicon case to match the midnight green.
zeblues
$59 can buy good cases like otterbox or even UAG already. such case can buy for less than $10.
Jirachi
It depends. Apple cases got a higher lip bump such that the screen won't come in contact with the surfaces. Any other clear case is a joke. It's not even protecting jack ****.
athenodorus
Should still be able to find similar one at much cheaper price. Transparent case should not cost so much esp when they will turn yellow over time and scratches easily.
$59 no joke sia. Can't justify at all. Unless theirs is very special.
Jirachi
Hmmm. Clear case I have no experience. But nothing came close to the leather one. The lip bump is really high. I’m super confident even after I dropped my phone.
