Oneplus 7!
WhiteAnt
you forget to mention the bare minimum of bloatware !!!!
i don't use netfix so that is the only bloatware i find in my OP7 Pro but for those who use netfix, i don't think you can find a single bloatware :s13::s13:
Still have some Google apps cannot uninstall... Like play movies, duo, Google (this duno what not useful), play music and notes..
Wish they can be totally uninstalled as I dislike them taking up space and might cause unintentional lag too. Never know what other apps might clash bc of them :crazy:
maybe the oneplus community app :)
Thought this one can delete? I alr deleted long ago lol. They secretly steal info huan. That time they pushed some unwanted info to all op users, can't rmb what issit but it did happen and people saying got strange words or sth appearing on their phones
tortoise18
How to activate pocket mode? My op7pro keeps unlocking itself or camera. Wasted alot of battery
ccloh
those are Google bloatware, all androids have unless you flash custom rom and install the pico gaap then you won't see all those except Google. this is not bloatware of oneplus lah. google movies and musics can be disabled. the duo if i remember correctly is for video call. Google this one can't touch if i'm not wrong as it is like the heart of the google play even the bare minimum pico gaap also has that.
WhiteAnt
I think notes is oneplus app?
Some Google apps are not useful to us as there are limited capability. Unless is in US then more useful. Nevertheless, they should let us delete those apps we don't want. Google play store can't delete is understandable as that one everyone will use. Optional ones like music, movie etc is too much. Actually if we want we can always download it, but so invasive to stuff it down our throats lol :o
shadow84
I dun see the Notes in my apps listing..
WhiteAnt
Idk how it got into my drawer :eek:
Can't find the listing in my Google play store as Well.. Duno how to check where this app came fr
<img>https://i.imgur.com/XCHvYBo_d.jpg?maxwidth=640&shape=thumb&fidelity=medium</img>
jtec14
I have it too, it is oneplus app.
GreenHorn
It's a oneplus built in notes app. For the memo/reminder used in their shelf.
Sent from OnePlus 7 Pro using GAGT
WhiteAnt
Thanks for the confirmation! Coz shadow say is not in his listing :s22:
Thanks for the confirmation haha, thought is some rouge app. So this indeed is oneplus app.
On the positive side, seems like can uninstall this! :o
shadow84
Tbh, i really dun have this app in my listing at all. But, i just go download coloured notes. Simple and works well.
impedance
I have the notes app in my listing as well.
The nilkin screen protector is good. Smooth and quite easy to paste.
Sent from OnePlus GM1900 using GAGT
WhiteAnt
Why got the circle thing around the can lens so ugly :s22:
Seems like 7t is an improvement for the camera. But I don't think it will improve the photo quality by another 50% with an additional lens :crazy:
Probably you've deleted it unknowingly :o for me ish use Keep
ccloh
don't find much distinctive difference between the OP7 Pro and the OP7T Pro except for the processor 855 and 855+. but then again, based on the normal type of apps we are using, don't thing we will find any difference. maybe intensive of gaming might be noticeable.
android 9 or android make no difference either as sooner or latter OP7/7 Pro will get the upgrade to 10 once it stabilizes.
however, for OP7 and OP7T, it is a significant difference. firstly is the 90Hz display. hell lot of difference with the 90Hz display. after getting used to the 90Hz from OP7 Pro, any display from other brands of hand phone just look .............
camera hardware spec wise, for OP7 is an upgrade from dual to triple. the main camera spec remain the same. the ultra-wide 16MP f/2.2 will be more useful than the OP7 depth sensor as those who like to take landscape shot will be able to capture "everything" inside the photo or put it this way, in a room when you have group photo, more people will be able to capture inside the photo at the same distance. telephoto is good for zooming.
for those intending to buy OP7 might consider OP7T as the "jump" is significant. price wise, based on h/w spec, probably OP7T just price slightly below OP7 Pro only (for the same storage size)
WhiteAnt
I think better to wait op8 to get a specs bump to sd865 nx year. Not so worth to get 855 if can wait a bit since alr half a year late. For me, chipset is v important and the most significant upgrade with all due respect :o
rootz
I guess 7T is more for ppl who has yet to move to OP7 or OP7P.
Existing users are very unlikely to upgrade.
ccloh
for existing user probably you want your OP7/OP7 Pro especially OP7 Pro to last 3 yrs and by then it should be OP10 already :s13::s13:
