Recommendations for fridges
VacheronLim
Are these 2 models the same and just different in colour? Any one using either one of this and how is it?
Panasonic NR-BX468GWS1
Panasonic NR-BX468XSS1
yes same model, just different color variant with an up-charge of $150 thereabouts
Phases
SS is stainless steel body, very nice, i like it very much but no budget for it. this model fridge volume is big but freezer volume quite small so if alot of frozen stuff need to weigh it carefully.
Posted from PCWX using dog walk volunteer needed, pm me
ichinisan
Thanks for the info! Btw do you have any idea if this Hitachi RV480P8MS-BSL is good? The capacity is bigger with more compartments. May probably go for this instead of the Panasonic one cos it is bigger.
merlot6230
moving out soon, used frig and washing machine to pay and collect for non fussy user.
pm
collection sengkang
Phases
no ideal, i bought another slightly smaller Hitachi model rb410p6msx, much cheaper (paid 680 only) than Panasonic with same bottom freezer design and 100l freezer capacity to store for my cheap frozen poultry volume order.
tortoise18
Gt the ss 468 fridge today! Really good looking..
And even though 450L same as my old fridge but looks huge! My older one has much bigger vege space but this fridge space is hugeee! Haha.. wish it had more egg trays and glass trays though
ichinisan
Is the stainless steel colour of the fridge you bought something like champagne gold? Or silver?
tortoise18
I bought during 9.9. from guy online after voucher discount $761.
But fridge from audiohouse. Think the guy is like middleman
Phases
price can go so low?
petetherock
Moderator
Moderator
Good price.
Bottom freezers are practical if you use the freezer often. It's easier to access the contents. But some of them are less energy efficient.
tortoise18
Can you vacuum under the fridge without plugging out?
and noisy today after i brought down the temperature to minimak. weird
Mystyque
Good price.
Bad for the back if you use freezer often and it is at the bottom unless you always squat down to use.
ichinisan
Do you still have the noise issue for your fridge? The noise happens only when the temperature is minimal?
