Nakedtoes
- Dec 9, 2002
Thanks for the reply!!! You using wax or pomade?
Matt wax...
I think someone mentioned that Ubersuave is a white label product.
So application will be the same as clay? I rubbed the clay gao gao until warm on my palm before applying..Matt wax...
Where do you get Firsthand Supply Clay Pomade, Arcadian Matte Paste from? My hair type is short/middle short thin fine hair.. is it suitable?
If you’re using conditioner washing, suggest to use conditioner first then shampoo.
The above approach (quoted) will result in over cleansing which will aggravate rate of hair fall, which is unnecessary. And of course, you will also unnecessarily end up utilizing more of your shampoo too.
Thank you for the reply.I get mine from SGPomade website. There are many other websites as well like Shopee, Lazada, etc. You can search for them.
Those 2 products should suit your hair type no worries. Because my hair is rather long and thick, and they were able to hold my hair as well.
If you are afraid these products are too heavy, you can try cream pomades. Such as Shear Revival Gray Ghost or Northern Light, but these have a natural to middle shine (depends on amount you put).
Yes this is true. But i have tried this method for volcanic clay, and it doesnt work. Because volcanic clay is really stubborn and hard to wash. Which is why i stopped using it within 1 week. Too much damage for my hair.
O’douds matte paste or Indian clay for fine medium hair? And healthier ingredients?
So guys. I've just tried a sample of Gerson and Co. 's upcoming homebrewed clay product. And if the final product is anything like the version I've tried - it'll probably be one of the best matte products that ive tried.
This is my honest, impartial opinion. Strong, dry, grippy, lightweight + high volume with ample product presence to last you throughout the day. The most comparable product to it would be Indians clay - except that this one is a lot less brutal. Plus its homebrewed.
Looking forward to its release. Would I be buying a jar myself? Yeah. This is legit stuff - most peeps know i wouldn't praise a product if i didn't believe it worked. This is some good stuff.
Thanks for the reviews. As usual my question would be how it compares with MM.
Thanks
Haha quite different products. MM is much more malleable - Gerson's clay is stiffer. Both have excellent endurance and presence in the hair though
Roger. Thanks. Whats the name of the product?. Easy to wash out?
If not malleable means can't restyle/retouch, pehaps few hours later or end of the day?
Hi
Can anyone recommend me hair tonic to nourish my hair?
A little background of myself.
I am a male in the mid 20s.
I have just went to a salon and they did a scan for me. The scan shows that i have oily scalp. Most of my pores only have 1 strand of hair and for those that have 2/3, the second or third strand are very short.
The person doing the scan keeps recommending for me to buy tonic for my hair.
Can anyone advise if there are any products in the market that i should try or if i should buy from the salon itself?
Otherwise, kindly advise the "ingredients" that i should look out for in a hair tonic.
Side note: I do not apply any products to my hair other than shampoo at the moment
Thanks in advance
Still fully restylable, just stiffer in the hair. It doesn't have a name yet tho, as far as i know. Release date is expected to be from mid Oct to early Nov
