Redmi Note 8
ablurcat
Anyone (bought from Finer) RmN8 with China Rom + Play store install and is happy with the phone?
Ordered on 1/9/19 but shipment delayed as was told RN8 will only be launched on 17/9/19.
Paid $229 for sealed set without playstore
installed.
Current price is $209.
matrix05
installed.
good info. Today is 17/9, unless XM play Out-of-stock game, your set shd be on the way. Sealed set Finer (?), no need to load playstore and can send out sooner. How do you intend to solve the playstore (since global/india/EU ROM not available)?
ablurcat
China rom also can install playstore.
kazuki666
Then am I correct to say that RMN8 on China ROM installing gapps to run like normal Android phones in Singapore, is the same as Mipad4 also on China ROM installing gapps???
Sent from Xiaomi POCOPHONE F1 using GAGT
carboy00
Yup, should work the same way as Mi Pad 4.
Posted from PCWX using POCOPHONE F1 Rosso Red
carboy00
Like how note 7 pro is ONLY for India and China, don't assume till the product is launched global.
Yes but the fact that a Redmi device with NFC has been cleared by IMDA means there's quite a high chance Note 8 Pro is coming.
Audiology93
Yes same.
Sent from LG G7 ThinQ using GAGT
kinderbuenojhj
Really hope they can bring in both the RMN8/Pro to sg this time ard.
previously they only launch India and Tiong market for the RMN7Pro ver, leaving only the RMN7 (and MI9T/Pro for those who prefer more "premium" Redmis) for sg/global market.
confused
Just got my note 8 pro. For those wondering if this phone with CN rom works with TPG, yes it does. Think I am the first one to confirm this. lol :)
wongminmin
i read the users saying got overheating issue for note8 pro....got such issue?
alex22
There's nfc on the rmn8pro, does it work for credit card payment?
It's got no dedicated memory card slot right
confused
There is a hybrid memory card slot, which shares the SIM 2 card slot. Only tested with CEPAS cards so far, NFC works in reading them.
matrix05
Good updates from those pioneers. NFC makes N8pro very interesting. What method did you used to load google services & playstore? Understand some do side load, some use china appstore to load, which is preferred?
