Oneplus 7!
ERT
Where would be a good shop/place to buy OnePlus 7 Pro at attractive price?
mackie8
Guys do u have the android 10 update?
Im using op7... No update yet
Sent from OnePlus GM1900 using GAGT
shadow84
Install oxygen updater in playstore to get the 2.02gb file then head over to settings>updates to install.
leon0079
The update works for local set? Cos my model is GM1913
Sent from OnePlus 7 Pro Almond using GAGT
C32B
I tried yesterday evening, and got nothing all. Read again and realise that not all user have the update. Is going batch by batch.
Sent from OnePlus GM1910 using GAGT
ccloh
updated to android 10 but one painful thing to do after upgrading is have to re-activate/re-install some of the local banking apps. all previously fingerprint login have to redo again...sigh..........
ccloh
use the oxygen os updater from google play, meaning you have to install that. that one is not the official app by oneplus. if you go the the conventional method of Setting -> System -> System updates you won't find it
C32B
I do have that app to do update. Am not using the Settings -> System update to auto detect updates. Just arrive frim the Oxygen Updater app, lol. Go home then update.
leon0079
Just updated on my gm1913. Kinda weird gm1913 supposedly is EU model and the build shld be GM21BA
leon0079
I guess his is non pro. Googled online and non pro is on 57AA. Pro is on 21AA
Sent from OnePlus GM1913 using GAGT
