Oneplus 7!
HuatKway
Any solid improvements to camera?
Now that mate 30 is like gg, feel like jumping camp. Samsuck updates just CMI
Mclairs83
1) i disable all my social media background usage of data, notifications and etc.
2) i clear all apps before i go sleep.
so far i don't really care about my battery drain overnight, partly because i got the warp charger
and i still got around 6hrs SOT everyday. i can monitor and let u know tomorrow on my finding
Tested. 6% drain from 2am to 7.30am.
Still on the original resolution and 90hz.
Sent from OnePlus GM1910 using GAGT
Mclairs83
Don't expect much. But u can use alternative like gcam.
ccloh
its a catch-22 thing. you can use 3rd party cam app like GCam, Open Camera, etc and they have better quality and more settings to play with than the stock cam. however, only the stock cam allows you to select which camera you want to use in particular the ultra-wide camera. unless you root the device and do some lower level work (can found in google how to do it) else any 3rd party cam app can't use the ultra-wide camera. i suppose not many users utilizing the ultra-wide camera as most ppl are just taking portraits, street photo, photo of food, water, macro, etc. those don't need ultra-wide. landscape, scenery when you travel probably you will use it.
for me, i have the 3rd party cam app installed and mostly use that. when i need ultra-wide i just take to the stock cam. quality wise, not much issue to me as i usually take both jpeg+raw so i can process myself with software on the raw to produce the quality i like.
ccloh
btw anyone feel there is a difference in display on android 10 when running games ?
can't exactly describe the difference but quite obvious. on android 10, the color looks more rich than on android 9.
Mclairs83
yeap. that's the reason why i have one gcam and one stock cam. although the stock cam is not the best.. but ever since i gotten OP7 Pro, they improve their processing image and still continue to do so.
yes. i figure that as well. maybe there is some settings that change the colour profile on the gaming mode.
which i can't be bothered really. :s13:
impedance
So far, how is android 10. Thinking of updating it. Not too sure is it buggy or face any major issues.
Sent from OnePlus GM1900 using GAGT
ccloh
apart from painfully need to re-activate or re-install those local banking apps so far no other issues face. the fingerprint sensor login method all deactivated sigh... this i believe is due to the development of the banking apps for security reason as other brands who upgraded their android version also face the same issue.
what's nice is the dark mode theme real cool. another i like is the ability to customize the button (size, shape, color). as mentioned earlier, in gaming the color looks riches.
imacbie
dun really see any bug.
updated since the day released.
nothing crashed or watsoever.
osmond19
After updating to Android 10, still possible to activate the volte using the previous mod PDC?
jeaimentvous
The white bar below the keyboard is quite annoying (but I think it's a gboard bug)? Not something Oneplus can fix. Hopefully it gets addressed soon!
ccloh
https://mobile.twitter.com/arter97/status/1176007420562137088
Kernel devs talking about potential memory issues on 10.
hmm..interesting. might be as i can't confirm also. this morning i found my memory usage is at the 65% while before update the memory usage is around 55%. OP7 Pro has 8GB RAM and most of the time won't use all the way there for me. moreover i do frequently cleaning up and freeing up memory so shouldn't be a problem to me even if there is. as long as they don't have battery draining up fast issue, shouldn't be a big problem to me.
DELTAFORCE
Hi there, anyone got the ambient light working for the notifications on OP7 PRO ? Heard from some forum the ambient light does not work on some sets. Anyone can confirm ?
Thanks
shadow84
Does anyone feel that the vibration even on max is quite weak for OP7? Im using on vibrate mode via the switch at right side.
YelloGorilla
Not sure about the other OPs model, the vibration is weak for OP3 also (currently also using OP7).
OP7Pro has a newer vibration motor. Maybe did not implement for OP7.
WhiteAnt
This has been a consistent common problem for op phones since the past
Only the pro version has got bugger vibrato inside
