iOS 13 bugs
888888888888
Like how it darkens out background img on its wallpaper and surrounding icons, dislike how it blackens out everything in Settings, not used.
laucm
Try le...
Still waiting for caltex to fix the bug.... Zzzz
Later have to bring my ipad with the ios12 to pay for petrol
saggice
yep now press and hold the apps, it opens a menu instead of going to the cross and moving mode?
the 3d touch 'peek and pop' feature is effectively gone on ios 13 on iphone XS max. now similar to press and hold, not pressure sensitive at all. what use is there now for the 3d touch sensitivity settings in accessibility..
argentinafa
Happened to one of my cards in my 11 Pro Max. No verification OTP. Deleted and re-added. Added successfully after that.
Initial setup of my wallet for applepay there is verification OTP. This morning I boarded a bus. Sensor couldn’t sense my entry. I thought something wrong with my 11 Pro Max NFC sensor. Went to nearest MRT hover above the card reader also to no avail.
I rem what you typed here. I deleted and re-added back my cc to my wallet.
Thereafter can use SimplyGo.
Tks!
snowboiiz
Any1 have issue going into App Store using mobile data. I’m unable to access (keep loading) unless I connect wifi den ok.....
metamofia89
Live wallpapers disabled but the wallpaper still moves in lock screen. Anyone has this?
dricas_007
Seem iOS 13.1 too many bugs. My bro iPhone 8 Plus notifications cannot pop out. Phone to phone or laptop tethering cannot connect, WhatsApp keep crashing....🤔
