reddevil0728
- Dec 16, 2005
The in denial kindwhat kind of question is this??????
you just sustained the injury?
so is there a reason why when u already know you can't do RT, you don't at least go get some sort of excuse but would rather be treated as a defaulter?nope, it happened v long. Just that the whole process from seeing GP> Specialist is super long
Can't you just go see a MO to inform that you are still seeking specialist consultation and is waiting hence you can't do RT?I wasn't able to get a long status on the get go. the process of GP to specialist take weeks to months. For a full excuse, its required you get 6 mths of excuse RMJ to be eligible to "excuse" ippt for this cycle. The time is simply not enough. It might sound silly, I rather be treated as a defaulter than worsening my injury.
If it is not possible, you will reschedule your your trip?I did, mo covered me for a short period (1 week). However, MO also said a medical review is needed for a long tem excuse after the specialist which is still insufficient time.
Hence forth, everything else ill just leave it to the officers to give me the judgment.
i'm here asking duration of the CMPB charge process, if its possible to reshedule the charge
1st session is a categorisation test, last session is another test to see if you meet your category/band standards or improved from your category. Just tank both sessions. And follow through motion for the 8 trainings in between.
If i attempt IPT this year do i need to pass the ippt in the IPT program? Or just do 10 sessions and considered pass, thanks!
Sent from Samsung SM-A730F using GAGT
once got the habit of going rt it doesn't feel that bad anymore
plus khatib fcc got chiobu FT
No more la. Don’t anyhow say. It has changed for some years back.
Chinese zehzehIs it the Malay minah?
defaulter because never complete 20.Hi all. If i am supposed to take 20 rt this window but i only attempted 5.
Is it considered ippt defaulter or considered taken?
How many rt i have to take next window?
Sent from Samsung SM-G955F using GAGT
Now change system already.
Default ippt, just continue with rt next window.
Default rt then wait for letter.
Hi can I book rt ippt before the 8th session?
