The Spectacles Thread. - Part 2
ralliart_ray
any shops carry mont blanc frames? like this kind of pattern
vbhelper
dunno everytime i did eye tests, my eyes can see the alphanumeric and red/green chart clearly
whenever I get make new spec and wear for a few days, i can't seem to see far clearly.
If both eyes can see clear individually but not together, there might be a chance you could have phoria/ accomodation issues. Pretty common symptom in people who needs to see near for long hours on a daily basis.
Probably good to drop by your usual optician to check your eyes in details to find our more about your issue though. If they can't check, you can drop by my outlet to have a quick check. :)
bluebellas
Was at jb city square. Salesman/optician(?) suggested progressive lens with zero degree shortsightedness. I only needed reading glasses but he said progressive lens means I won’t need to remove my reading glasses if I also need to look at something at normal distance... any thots on this?
MrBoxySquare
Am in Osaka and will be in Kyoto and Tokyo. Any recommendations on shops for japanese handmade frames like yuichi Toyama?
Buy what you need. No point falling for pushy sales to only find out that you don't need those unnecessary stuff later.
If you work deskbound, a pair of reading /office lens would suffice.
If your work require you to walk around and see near at the same time, then a pair of progressive lenses would be suitable
bluebellas
Thanks for your advice! Another question. My first time making reading glasses. Frens say can just buy off the shelf. Wats the dif from buying off the shelf other than costs?
Off the shelf types are considered readers. The lenses used are usually made of acrylic and are way inferior in optics compared to custom made (Opthalmic) lenses. Usually good for up to 15 mins use to do a quick reading.
Custom made ones are prescribed according to your eye's degree and usually are more comfortable as the material used is better and takes into consideration your eye pupil distance.
rororocks
Hi I'm looking to get a pair of specs made
- lazy eye, both eyes day vision acceptable
- right eye vision close to perfect
- left eye vision is around 600 I think
- night vision is horrible, can't sleep bus numbers further than one bus length away properly (only started this year)
- in light conditions such as the bus numbers in boon lay bus interchange also cannot be read properly at approximately one bus length away (only started this year)
- spends majority of in front of the computer so looking to get a good blue light protection
- left ear smaller than my right ear so normal specs tilt unless some kind of adjustment is made
I've read a few pages on this thread and I think I should be getting
- a tokai lutina lens 1.6 and 1.7 index
- a Ray Bans RB6378 frame
Would like some advice please
bluebellas
Thanks so much for sharing!
