How's the APP compared to the E8? I've been using the E8 for quite a while...I like the in ear comfort and active noise cancellation of the E8.
For your info, the E8 does not have ANC. The E8 toggles between transparency mode (ambient) and your music mode but you can adjust how much transparency to your music or can block it 100%.
In this mode when you listen to your music and toggle to full ambient (without music playing), it's similar to AirPods Pro's ANC in the 'off' mode. But when you select to enable ANC and toggle between transparency and ANC, the ANC will further filter out that remaining ambient noise. But ANC does not 100% filter out all ambient noise so you will still hear a bit it, but lesser than when you plug it the E8 without playing any music.
Sound wise the E8 is still better overall and more detailed, though the AirPods Pro is still not too far away.
