Oneplus 7!
impedance
Yeah. Mine started 2 days ago. Can't seems to shake it off. It is like draining quite a lot. Can't find any solution online as well.
Sent from OnePlus GM1900 using GAGT
C32B
Even ES Explorer also shows sign of draining battery.
Sent from OnePlus GM1910 using GAGT
WhiteAnt
https://i.imgur.com/cF2tC6Il.jpg[/IMG
[IMG]https://i.imgur.com/zs8Jo4Dl.jpg[/IMG
Any one facing this issue? Whatsapp draining battery. It just suddenly drain the battery from that day onwards
Sent from OnePlus GM1900 using GAGT[/QUOTE]
I don't have battery draining issues but I can feel the battery isn't as strong in android 10...
jtec14
I enabled the option in camera settings but i dun see any extra button when taking photos. The icon nvr appear at left of video, photo, etc.
Just point at the QR code and the link will appear within the screen after a short while. No extra button or icon
shadow84
Press and hold for google lens to scan and let me know works 100%. Sometimes when i 1st open cam app and scan qr code, the message appears. Did it again when same qr code and cam app not reopened, message nvr open. Close and reopen app sometimes will see message. lol. But press and hold works 100% for now
ccloh
never try QR scan using google lens but i did use google lens to scan korean words on those cup noodle and get it translates to english. it works
jtec14
Huh? I just point at qr code only. Never use google len. Worked well scanning the same code repeatly.
Tord__
Qoo10 has a $111 dollar voucher for double 11. Currently it's maxed out you have to wait until midnight to grab it.
haojie91
Anyone experiencing severe decrease of SOT these days? My batt draining sibei fast nowadays
impedance
Me too. Having this issue. But mine is quite related to whatsapp. But I still find it quite draining. Not sure why though.
Tried installing whatsapp beta. Seems to find better but still finding it not as lasting as previously
ineser
Those with WhatsApp did you enable finger print?
Heard battery draining issue due to finger print
Posted from PCWX using HD1900
impedance
Not using any fp for that. No changes, I cleared my system cache as well. Until I use whatsapp beta.
Now is a lot better.
haojie91
Ah yes. Did a quick check and it was indeed whatsapp draining despite not having fp enabled.
What settings are u using ur phone at though? 68% lasting 15hrs is pretty darn good
