OnePlus 7T
Sauron
China set with global rom can log into local bank apps? Any one can share? Thanks
ccmheoa
Got so troublesome ma?
I used this procedure...
https://www.getdroidtips.com/how-to-enable-volte-and-vowifi-on-oneplus-7-pro/
I just tried enabling VoLTE, just sharing with those interested
Guide to enable VoLTE
1. Download these 4 files:
QPST (Install on PC) - https://androidfilehost.com/?fid=11410963190603912872
Qualcomm Driver (Install on PC, select WWAN option) - https://androidfilehost.com/?fid=11410963190603864074
Oneplus logkit (Install on phone) - https://forum.xda-developers.com/attachment.php?attachmentid=4763657&d=1558542807
Oneplus Engineering Mode (Install on phone) - https://www.apkmirror.com/apk/onepl...-0-171117173719-25c8842-android-apk-download/
2. Install the files as mentioned on PC/Phone
3. At phone dialer, key in *#800# > oneplus logkit > Function Switch > Tick "VoLTE Switch"
4. Reboot the phone
5. At phone dialer, key in *#801# > Engineering mode > ON "Full-port Switch"
6. Launch PDC Software on your PC
7. Select the Qualcomm WWAN Adapter
8. Right Click "Oversea-Commercial_DS", deactivate Sub0/Sub1 (Sub0 is SIM1, Sub1 is SIM2)
For me, M1 sim is in Sub0, so i only deactivate Sub0
9. Scroll down, and find and Right Click India-VoLTE-Vodafone > Set SetSelectedConfig > Sub0/Sub1
10. Once done, click on the Activate button below to activate the VoLTE Profile
11. Reboot your phone
12. Go to your Settings Wi-Fi & Internet > SIM & network > SIM 1/2 > Toggle on VoLTE
13. If everything is successful, the VoLTE icon will appear on status bar
Disclaimer: Try it on your own risk, dont claim from me if your phone up lorry :s13:
liehuo
This works. The volte option can be seen now. How to test if it's really working?
blastmachine
Mine also same. Did enquire them. This is what they replied. Won't expect the phone by this week though, most likely next week 😌
Me too. Need to check with them what is happening? I thought they have ready stocks.
Loser
LOL that one will only work with telcos that already fit the default profiles. Singapore telcos require the extra steps to enable the compatible profile to work.
If VoLTE shows in your status bar then you will know it worked. :s13:
KeYoKe
