Redmi Note 8
davidwong
Why need to settle when you are already aiming for a high end phone just pony up a bit more money to up the storage of Mi9T pro la cos if you are looking at Mi9T pro meaning you are looking at 855 or amoled or both, why back down to note 8 pro
And if note 8 pro is sufficient for you why are you looking at mi9T pro? Very strange logic.
Unless you meant Mi9T then pricing also only 50 bucks diff.
I was considering Mi 9T Pro. But I realised that I need storage. So have to settle for RMN8 Pro with microSD card slot.
NightRaven49
maybe he meant expandable storage, like maybe his sdcard already have photos and videos then just put in phone can liao. the only phone with 855 and sdcard that i can remember off the top of my head is the zenfone 6, and even that has a pretty subpar (tho not garbage) ips and isnt the cheapest phone around.
if storage really an issue then can buy k20p prime with 855+, up to 512gb of internal storage :s22:
Hailgod
the problem for me as price range keeps going up
the next upgrade range is so close 😅
yeh. when the note 7 just released, it was like 330+ in sg. poco f1 was 400.
the choice was so obvious, a 660 can never compare to a 845.
Audiology93
Which shop ?
Carousel? The shop seems like Univercell to me.
Sent from LG G7 ThinQ using GAGT
teoph04
Can advise what's the difference between the pro n non pro version?
Sent from HUAWEI ALP-L29 using GAGT
Hailgod
note 8 is probably going to get updates faster and longer than the note 8 pro.
davidwong
Faster for the 1/2 year yes but may not be longer as k30 is confirmed using MediaTek chip 5G soc so May have continual supper moving forth
teoph04
Why so? Isn't note 8 pro a more premium one that 8? Sorry for the question as I'm buying xiaomi phone for the first time.
