Nintendo Switch thread - Part 3
Snoweagle
The only physical games I have is let's go eevee (came with console) and super mario odyssey. The rest all digital.
JAson1980
My third Nintendo Switch console has arrived! :s12: :s12:
Now to look for accessories... :s22: :s13:
Bro, found lobang for the thumb caps? Especially in the original color?
I getting a Glass SP and a 8bitdo controller (Only yellow or cyan, Pity no light grey,). Pity the lite cannot dock though.
invigo79
Is sd card needed to save game file ?
Nope. Save game files are stored inside the internal memory (32gb).
Personally I use 128GB sandisk sd card. So far no issue with storage space.
Sent from Home using GAGT
PierceLee
https://en-americas-support.nintendo.com/app/answers/detail/a_id/22481/kw/microsd#s1q4
What information can be saved to a microSD card on Nintendo Switch?
  • Downloadable software
  • Software update data
  • Downloadable content (DLC)
  • Screenshots and captured videos
Important: Game save data is stored to the System Memory and cannot be copied or saved to a microSD card.
If you don't have SD card, these go to the system memory, which is very limited in capacity (32GB). Remember, even if you buy physical games, there are still patches (can be quite big) and DLCs. And some games are incomplete on the physical card (like the NBA 2K games), you still have to download a big chunk to play them. And note that game saves are on system memory only (some saves can be quite big), that should be the highest priority for using your system memory. So you will want to have SD card to hold everything else.
zensushi
Moderator
Moderator
Not yet. Haven't bought SP & case(s) either. Have recommendations? :o
zensushi
Moderator
Moderator
so in short microSD card is needed for console
Whoa! That means I have to get 3× microSDXC cards! Maybe buy the Samsung EVO cards from Amazon again. I use them in my phones.
JAson1980
TPU back cover with grips.
https://www.aliexpress.com/item/4000262617426.html?spm=a2g0o.cart.0.0.67423c00cM5mBd&mp=1
Thumb grips, i think look closest to the color liao.
https://www.aliexpress.com/item/32814362091.html?spm=a2g0o.cart.0.0.67423c00cM5mBd&mp=1
Generic tempered glass SP
https://www.aliexpress.com/item/4000013511980.html?spm=a2g0o.cart.0.0.67423c00cM5mBd&mp=1
8Bitdo controller
https://www.aliexpress.com/item/4000310567898.html?spm=a2g0o.cart.0.0.67423c00cM5mBd&mp=1
pity no light grey.
all in cart, waiting for BF sales on aliexpress.
I am getting the Gulikit BT adapter as well.
vaxvms
amazzon.sg not sure cheaper and faster or not
sammy card nvr go wrong
zensushi
Moderator
Moderator
Thank you for the great sharing! You're too kind! :love:
wenghan
Spoiler (image attached)
For those who have not bought it yet.
Sent from Xiaomi MI PAD 4 using GAGT
