Window 10 Pro V1909
Norman Chan
Anyone face the problem after fresh installed the Win 10 Pro , under NetWork File sharing after you enable this function (Auto discovery) , the computer still failed to detect our Users connected to the same NetWork ?
Thanks in advance for answering.
cscs3
Control Panel - Program - Programs and feature - Turn Windows feature on or off - Tick/turn on SMB 1.0/CIFS file sharing support
reboot and that should fix your issue.
jas1701
If your Win10 is updated from 1511, 1703, 1803 & 1809, the above feature is already enabled.
If fresh install using 1903 & 1909, it is disable.
uncle_josh
The Computer Browser service relies on the SMBv1 protocol to populate the Windows Explorer Network node (also known as "Network Neighborhood"). Microsoft officially disabled SMBv1 protocol with the Fall Creators Update due to the WanaCry Attack.
You can google the internet for more information
Norman Chan
Thanks for the info.
Norman Chan
Is there problem with WD MyBookLive Network detection in Win 10 Pro?
Seem like playing hide and seek , sometimes can detect and sometimes just no where to be found.
jas1701
Talking about ext portable HD, notice the front of the USB connector not able to provide the power to it. Only from behind the board USB no issue.
