can tell us what so good about that used mavic pro?
i record video in 1080p only, not 4K. to me the only thing attractive that mavic pro has is ocusync. for me, if i need to buy one, i will only get that used mavic pro flymore at S$450 or else i go get a new mavic mini flymore at S$650.
- front obstacle sensor: mavic mini does not have this but you really need skydio2 type of obstacle sensors to be useful (mavic2's side sensors are shut off during p-mode). front obstacle sensor might help but that alone is not that useful to prevent crash.
- ocusync: this makes mavic pro much better and having stable range of ~500m inside s'pore. I guess mavic mini should have a stable range of ~250m, and on wifi you might encounter 1-2seconds of lost fpv feed on phone when taking video.
- dji googles: dji googles work better on ocusync
- thrust power: mavic pro has thrust/weight ratio of 2.5 and mavic mini about 2. mavic pro will be more stable under strong wind. for mavic mini you need to change to 1100mah battery (japanese 200g version, 18min flight time) to have thrust/weight ratio of 2.5
- extra batteries: mavic mini's batteries are cheaper
- weight: mavic mini is much lighter for tour, and smaller batteries easier to go through air safety checks. each mavic pro battery alone is 240g about same weight as a full mavic mini drone.
- 4K video: mavic mini only has 2.7K video.
- Flight time: Mavic Pro 25min, Mavic Mini 30min. Mavic Pro flight speed 20% faster in p-mode
- used item: you do not know the condition of that used mavic pro you are buying.
