Starhub Giga
xonix
Network is down ? I was on my phone all the way from Woodland to Kallang this morning, on train and bus. No issue at all.
jerrypt
Did they say what will be the subscription for the new 'pop up' plan after 15 Dec 2019?
*adiBOY
$18 lo. The deadline is for signup. After that won’t have such deal anymore till they release another one.
oliverong1995
Giga tips
you can port in later after you already sign up and received your SIM card
click the menu button on extreme right and menu pop up
tap port-in to giga follow instructions
your port in number will replace the giga number
daranic
Giga tips
Any idea if can sign up on 15/12 but ask to port in on 26/12? Tried to ask via the app but no one reply.
zuppeur
Yes. Can port in later.
Does it mean giga will send me a sim card with temp number that I can use temporary.
When my contract with other telco end, how do I inform them process the port over?
crystalnox
Giga will send you the sim card with a number, you can use it forever or initiate a port in anytime you like. Just don't indicate on sign up that you're porting in yet or they'll start your port in as soon as you activate the card.
vsvs24
When your contract ends and you are ready to port in, use the app to initiate port in. The port-in number will take over the temp number on the same SIM card.
JLowX13
Hi. On the activate the card. So as long I dun insert the new SIM to my phone is not in used? Start date is the day I insert the sim card and use it.
Thank you.
crystalnox
Thank you.
Once you press activate in the app, it’s activated already. Not sure how long they let you keep an inactivated sim card.
