OnePlus 7T
ineser
wah, that seems like a lil turn off if the battery capacity at 100% only has 5 hours SOT... After using for one year will become worse :/ Now that got me thinking if rog phone 2 is a better option for me ...
Guess it's due to 90 Hz. Next year phone will have 120Hz will be crazier
Posted from PCWX using HD1900
casshern
Anyone knows of any good screen protector selling in bugis area?
Also, does anyone whatsapp do not have the drop down "heads up notification" when a message comes in? Only sound and vibration with icon at status bar but no drop down like rest of the apps.
ineser
Darn bought some cheap tempered glass protector but can't fit well with Ringke Fusion-X. Anyone has good recommendation for cheap tempered glass protector that fits well with Ringke Fusion-X?
ctstalin
Got try the official tempered glass sp? I bought from JD.com and it fits the free casing that came with the phone
Posted from PCWX using ONEPLUS A5000
karlheng
Does it reduce the sensitivity of the fingerprint sensor? Is the screen protector of full adhesive type?
ctstalin
Didn't feel any difference with fingerprint sensor. Ymmv
Full adhesive
casshern
Hu just checking with u all, is there a option Hearing aids in the Accessibility menu?
I found this option
coolhirako
Anyone know a good service to apply a good screen protector
Flat screen like 7T is quite easy to apply tempered glass screen protector by yourself.
Outside those shops dont know got 7T tpsp or not.
I know 7pro got WSD only
karlheng
I recently tried "UV Liquid Full Glue Tempered Glass For OnePlus 7T Pro" from Shopee. It was quite easy to apply and the effect was quite good. There were a few little trapped bubbles that were negligible and the fingerprint sensor response was much better than using those screen protectors without full adhesive.
