Nintendo Switch thread - Part 3
Mzeria
How to remove dust trapped under the actual screen?
As i am using a screen protector the specks of dust gets magnified somehow. Are there any places which help to do this safely?
Shinta
Hi Guys, can I use Gen 2 Switch with a Gen 1 Dock? Concerned I might fry the system
Sent from Song Bo using GAGT
JAson1980
any physical shops selling that Skull & Co Switch Grips?
anyone knows??
My setup with clear TPU cover with grips and skull & co thumb grips
LegendZenify
same here .. but I'm more concerned if it's still worth buying?
Why not?
Switch has a huge library, great exclusives (Pokémon, luigi's mansion, etc.) and it's not near the end of its life cycle yet. Plus the new switch has improved battery life, making it better for portable play, not to mention the switch lite.
If anything, it's more worth buying than it was 1/2 years ago.
Sent from Samsung SM-G975F using GAGT
JAson1980
zensushi
Moderator
Moderator
Switch Lite or Switch Gen 2?
If you want a strictly portable system, get the Nintendo Switch Lite.
If you feel that you are likely to have it docked every so often for playing on your big screen TV, get the bigger Nintendo Switch.
The weight difference is significant.
Ye_Rongtian
Will be going for Switch Lite then. Price also $200 cheaper :s13: Is there any way I can view the price of the digital games?
LegendZenify
You can see the prices of the digital games here: https://www.nintendo.com/games/switch/
At full price, you can get physical copies for a fair bit cheaper than the digital.
(for eg. luigi's mansion is 60 usd on eshop, physical copy from korea is 60sgd :s12:)
