Samsung Galaxy Fold
dgeralds
anybody using dual sim (eSim + physical sim) in galaxy fold? How is the experience? Does any app have problem working with galaxy fold? How about secure folder?
Glariel
That looks interesting.
Had my Fold for 2 weeks and not a single scratch/dent on the inner screen.
Receiving my UAG case either today or this week. They refunded my leather case, saved $129 :s22:
Will keep the spigen thin case though so have 2 cases for my Fold. I think once I use the UAG case I won’t be using the thin case anymore
Healing Shield Peel Test :s12:
No offence, but if you using it as a daily driver, and not babying it, then i say its not possible. Lol
Glariel
Just collected my UAG case after work, the case is so thick, but then the protection is good. Easier to hold also as compared to what the others said.
No regret buying it. Finally just in time for new year can bring out Liao. When I got the thin case from spigen I was quite scared to bring out cause scared later the letter in the hunch will drop. I guess I will keep the thin case as spare since I can’t return
SEI1987
Has anyone done the screen replacement yet?
Do they give a new set or?
It's basically a new phone they give you. When I replaced my screen it seems like the got a new body and just transfered the old motherboard over as the phone is brand new but imei stays the same
ccmheoa
I got a tiny scratch on the display and the spindle frame, eye sore basically...
Wondering if worth it to use up the one time replacement that can get rid of both
Glariel
can show the tiny scratch on the display?
wait until warranty going to finish then do the replacement
who knows you go accidently scratch again or something.
yesterday I just cut my nails, quite long already so scared later use liao scratch the screen. used 2 weeks already only the screen protector got scratches and bubbles due to casing, changed from thin case to UAG case other than that looks ok. inside got no scratch.
SEI1987
Don't think it's worth it. I scratched my screen with my nail very deep on the 2nd day of ownership. I left it like that for 2 months before I went to Samsung for a different issue. The screen coating was wearing off the screen. I claimed that under warranty luckily
