Recommend a durable 3rd Party Cable for iPhone
007Mi6
Apple usb c 30w charger worth it ?
It is neither here nor there. IPhone 11 Pro Max charged at a peak of 22w. It would have been better if you have a dual port 18w plus 18w (usb pd and quick charge 3.0) for charging the iPhone and a powerbank on QC 3.0.
cnt
Used a power delivery adaptor so odd when I charge mine iPhone or andriod ok but charge iPad mine iPad can't press home button it can't go to home it got struck but when I unplug the charging cable it's ok
You using what cable?
ApexMan
Using appke cable or ugreen
After some goolge found out it might be the new power delivery charger notvas good
So it's affect the touch iD
I use back apple charger no issue at all
That why I plan to hoot apple 30w usb c charger
cnt
I’m using anker 5 ports charger with pd charge my ipad. No such problem
ApexMan
Is this ok ?
Anker PowerPort Atom PD 1(PD対応 30W USB-C急速充電器)【GaN (窒化ガリウム) 採用/Power Delivery対応/超コンパクトサイズ 】 iPhone 11 / 11 Pro / 11 Pro Max/XR / 8 、Galaxy S10 / S10+、MacBook、その他USB-C機器対応 (ホワイト) https://www.amazon.co.jp/dp/B07DHQKQPL/ref=cm_sw_r_cp_apa_i_UFkfEb89YKMYT
Or
RAVPower USB-C 急速充電器 (30W 最小クラス PD対応)【GaN (窒化ガリウム)採用/折畳式/PSE認証済】iPhone 11/11 Pro/XR/8、GalaxyS10、MacBook、iPad Pro、Nintendo Switchその他USB-C機器対応 RP-PC120(ホワイト) https://www.amazon.co.jp/dp/B07WWDSRJ2/ref=cm_sw_r_cp_apa_i_CGkfEbNFKGHN0
cnt
Is this ok ?
Or
The anker one is the one I posted above. They have a shop at plaza sing. Ravpower I heard not bad but never try before. I only buy anker one
007Mi6
Ya I don't need those as I already got those at home to slow charge mine power bank
I just need a fast charge portable enough to have a quick juice up
Thay why I consider the apple 30 w usbcc since the new charger I got don't seem to work as happy to mine iPad but andriid & iPhone ok just only iPad odd
Ur iPad is the 12w old version. The Anker 30w charger is $30++.
If you really need a spare compact charger, you should consider Ugreen 18w USB PD charger at $14-$16 unless you have plans for a new iPad Pro months down the road.
ApexMan
Ya that why I considering the apple 30w due to mine 3rd party power delivery power adaptor when I charge iphone or andriod ok but only iPad pro gotvissuec like I can't press home button to go to home until I unplug or use back the iPad charger
So now im considering the ravpower gan 30w or
Anker gan 30w
