Your Miui must be before Miui 10, Kotty can guide u on this.I saw this on a seller page on Qoo10.
"LTE version does not support phone call function."
Is it correct? Mi Pad 4 doesn't have a version which supports both mobile data and phone call?
Which shop sell screen protector for Mipad 4 and help you to install?
Not in play store. Must sideload and only playback in 480p.Mi pad 4 can't Netflix?
Sent from Xiaomi MI MAX 3 using GAGT
If watching anime, yes. Quite distinguishable. But that's just meCan u really see the diff between 480p and HD on mi pad 4?
I usually don't download because streaming has no issues for me.but only when u are streaming it right? how about when u download the shows?
SLS level 4 should have 2 shops (related) that sell TGSP and cases. One of the shop is at the corner nearest to the escalator. Last time, I bought for my MiPad and SP4. They specialise in TGSP, skins and cases.
Posted from PCWX using
Where Does My QR Code Goes To?
Thanks. I'll go and check it out. Do you know how much?
I asked at a shop at Parkway, tempered glass $28!! Might as well buy 50 pieces from taobao and do it myself trial and error.
The JB shops don't have, understandably so since Xiaomi doesn't sell this model globally.
Which 8 inch tablet do you recommend for Netflix?
