Samsung Galaxy Fold
Is it true - The Galaxy Fold will be priced starting at $1,980 in the US, and presumably, that will be for the 4G LTE model. That likely means the 5G version of the Galaxy Fold will be priced at well over $2,000. This ex????
Gaminator
In my opinion the best overall protection. Thick n solid.
Bro, compare the hinge protection against the UAG Monarch Fold case, note that no part of the hinge is left exposed, hence better protection.
808ster
But expose here. Tough armour cover entire side. So both are great. But tough armour hard to type on the front screen. It's hard to reach the corner.
SEI1987
returning my UAG case.
too bulky for my liking
How are you returning things? Where do you buy from that you can buy something use for a while then return. Think you said your leather cover you also returned. I'd like to shop where you shop
Ye_Rongtian
He kope and put back when it is not to his liking. :s13:
Glariel
Lazada lor
:o
garychengjw
It's very suay to met buyer like Glariel. Used and return.
Sent from LG V50 ThinQ ~Black~ using GAGT
Glariel
Doesn’t fit.
Leather case too tight
UAG damage my screen protector.
I only have the thin fit case now which I find it still the best although the hinge is exposed, but I will take extra care of it
Never knew you can return on lazada if you didn't like the product. What do you say to them?
