UniFi Setup | Dream Machine
candrox
Hello,
Wondering if we have any UniFi experts here? I recently got a UniFi Dream Machine to replace my existing UniFi setup (CloudKey, switch, access point) but run into some troubles.
Current Existing Setup
ViewQwest Fibre Modem
US‑8‑150W Switch --- CloudKey
| --- Wired devices
Unifi Ap AC-Pro --- Wireless devices
• 10.10.10.0/24 | Management Network (Routers, Switches, Servers, etc)
10.10.10.1 - ViewQwest Zone Router
10.10.10.5 - UniFi Cloud Key
10.10.10.6 - UniFi Switch 8 Port
10.10.10.7 - UniFi AP-AC-Pro
• 10.10.20.0/24 | Home Network (Computers, Phones, Tablets, etc)
10.10.20.1 - Computer
10.10.20.2 - Computer
10.10.20.3 - Phone
10.10.20.4 - Tablet
Internet connectivity is provided by ViewQwest vi a Zhone 2424A Router which also handles DHCP:
The existing, standalone UniFi CloudKey has correctly 10.10.10.5 assigned:
New Planned Setup
US‑8‑150W Switch ----- Wired devices
UniFi Dream Machine --- Wireless devices
Now, switching over to the new UniFi Dream Machine setup, I want to keep the same IP subnets. Currently the integrated CloudKey has the default IP 192.168.1.1 assigned. There is no option to change the IP anymore in the CloudKey configuration page (as shown in the screenshot above) so I assume that this has moved into the general UniFi setup page.
UniFi Dream Machine WAN Settings
What should go into the WAN settings? Should the IPv4 connection type be left to 'Using DHCP' or should that be switched to a static IP? And if so... which IP (as I also have a public IPv4 address)?
UniFi Dream Machine LAN Settings
And for the LAN settings - what should the 'Gateway/Subnet' IP be? Also assuming that DHCP should be switched to 'None' if the Zone 2424A keeps on handling DHCP allocation?
Thanks a lot!
omelet
Not a Unifi expert....but you can get Viewqwest to configure your zhone router to bridge mode, so your Unifi Dream Machine will handle the DHCP...and be the main router.
Btw, where did you get the Dream machine? :s11:
t258jgn
Zhone --> UDM ---> US-8-150w
U need to contact VQ. Provide them mac address of UDM & ask to set bridge mode
terminater
Am interested to know where u got the dream machine as well! How much is it? How is the range on the AP?
mrkiasu
You can get it in Sim Lim Sq or from @t258jgn .
Just wondering why you don't just bridge your VQ zhone router and let the dream machine do all the work. Let the Zhone thing be an ONT.
The Dream Machine has the same AP as UAP-nanoHD.
candrox
Bizgram at Sim Lim Square 05-50 has the standard and pro version in stock for some time already:
Ubiquiti Unifi Dream Machine ....................UDM ............. 529.-
Ubiquiti Unifi Dream Machine PRO.................UDM-PRO ......... 898.-
Initial setup will be 'Zhone --> UDM'
As I have admin rights on the Zhone 2424A I can disable DHCP and let the DreamMachine handle IP address assignment. If possible, the Zhone 2424A also has some Ethernet ports I want to utilise. In this case I assume there is no need to contact ViewQwest?
I guess that will be the most reasonable approach.
What would be the IPv4 connection type that goes into the WAN configuration?
And what would be the Gateway IP that would need to go into the LAN configuration?
t258jgn
UDM-PRO is still in Beta Testing Phase.
Better chk with them the source of their Ubiquiti products :s22:
4 years ago I used Zhone. You can't do much things when u log inside Zhone.
It slows down speed & always DC when using as ONR
Later I use my own router & ask VQ to set Zhone as ONT in bridged mode.
Few minutes job over the phone
The speed so much better :s12:
I you still wish to use Zhone as ONR then
Zhone (192.168.1.x) ==> UDM (Disable the Router & use as AP) ===> US-8-150W
mrkiasu
Ignore the price for PRO for now. Just there for fun, normal home users wont need it.
Farish
Boss, the UDM-PRO still doesn't support an external Cloudkey right? Will it eventually support one or will never support external CloudKey?
mrkiasu
Never support external cloud key. UDM-Pro no wi-fi.
After CNY...lets celebrate CNY first.
That7days
Hi,just curious abt the Dream Machine...am new to Ubiquiti system.Am in 4rm bto,wifi sucks,so used velop(SH)one in hall,one in middle room.If I wanna use the dream machine,..
how the setup will be..?
Hows the band broadcasting range?
Eg.ONT> modem> dream machine> ap ?
giraffey
- You can setup UniFi as an AP (wired backhaul) or Mesh Mode (wireless backhaul).
- The setup would be: Termination Point (TP) > ONT (Modem) > UDM (Router) > Additional UniFi Access Points (AP).
- If you do not need the security features of the UDM, you can also any other router, and just get 1-2 UniFi Access Points. Depending on the house layout, if you can centrally locate your Access Point, 1 AP could just be required.
miloaisdino
udm should preferably be connected directly to ont as it has superior routing capabilities. you can reuse your old router as a spare ap as well
That7days
Thanks for the reply. By itself, how good is the UDM, as a wireless router? As in the 2.4ghz n 5ghz range?
giraffey
I don't use the UDM, so can't comment. But, with 1 UniFi AP, am able to cover almost the entire house (except the kitchen) due to my house layout. So had to have another AP to cover the kitchen.
If range (coverage) is a concerned, go the the UniFi Long Range one.
That7days
Ok... thanks..
BradenHeat
Here where i come in :o:s13:=:p
- wifi is definite closer pro-sumer level
- i can hit wifi 5 max speeds on iphone 11pro max [ when standing directly infront of the UDM itself ]
- range wise 800sqft with normal and usual wall + door, will cut performance by 30% within 2m range
anything beyond 3m, say from main living room to batheroom, will drop another 20%
[ just by my own experience, when trying to stream netflix or youtube whilst showering ]
- within the app, you can opt to tweak ALOT of settings which other gaming routers might not even come close.
all in all, if you're in a landed property 1 UDM + 1 NanoHD = full coverage [ decent speeds]
however if you're cover say 3 levels and what not, then you may have to us more satelite.
BTW the interface has alot of customisability and information you need at a glance.
That7days
Wow, thats a lot of info😇...Thanks👍
BradenHeat
No problems,
There’s a lot of sleeper pro here lol , the main thing I gotten the UDM. Is because of the all in one for SEcurity gateway and other aspects of the IDS/ IPS etc
This is on top of its very capable wifi which can easily work well with other routers being in bridge mode
Usually I would recommend this device should my less tech savvy folks want a all in one package that is more security focus
Asus and the rest is up for toss , even if you get a pfsense device , it will be really overwhelming, thus the UDM
