Anyone here is using APOL chairs?
$howm3h0w
Hi there good evening all,
I have stumbled upon this ergonomic chair company call APOL,
Since my chair is in the mids of broken & would like to invest in one of it,
I would like to get your feedbacks & comments about it.
Does it stands out with it's competitors out there?
Thank you all!
tigerwoods
Thank you all!
All same lah from same supplier
Posted from PCWX using Jedi mind trick.
Ark Law
Either invest in a HM or get used generic office chairs from Carouhell on the cheap.
$howm3h0w
Thank you so much for your wonderful comments, I appreciate each and everyone one of them.
A few days back went down to their showroom located at Ang Mo Kio, I have tried out 2 chairs given my bui bui size, it was a tough decision between the Kraken & the Behemoth.
Both are not bad, for the Kraken the lumbar support pillow stays into place but for the Behemoth, there will be times it will drop. No choice.
Hopefully when I got enough cash to invest in it.
As for people saying to invest in HM,
To be frank mesh chairs are not my things. Not saying its bad but our body need to see which type of chairs fits our daily needs.
Thank you all
localITguy
Suspended
why pay so much for the same thing?
go QOO10 search for gaming chair
i got mine for 90SGD
if spoil/peel just throw. all same OEM/ODM product
Trans-Am
Thank you all
Should consider mesh chair:
1) no need to worry about peeling issue
2) much more cooling
Sent from A universe Where pink PWNED everything using GAGT
Be@rbrick
Thank you all
Hey there.. I'm like you. bui bui also at 120kg. got myself a behemoth during last year nov IT fair.
$howm3h0w
Hi there all,
thank you so much for the replies once again, really appreciate them.
To bro Be@rbrick: How was it so far? Way better than it's competitors & most important, how is the lumbar support pillow?
Thank you
Be@rbrick
Hi there all,
Thank you
For me I can’t find the difference between both in terms of comfort. They’re both similar in my opinion. For the lumbar pretty ok, the difference between them is I think Secretlab lumbar is built in if I can recall. There’s a knob at the side of the chair. I took the synthetic leather instead of fabric knowing that it will tear few years down the road. My 3rd month now using and playing wow about 3 hours daily. So far so good. Reason for choosing this is because of the price factor also. Best is for you to try both on them and test. Everyone have their sitting habits ( for mine mostly keep crossing legs etc etc ). Cleaning wise I’m using the Armour All Car leather care. So far ok for now. Hope this helps.
Swiftbladez
One thing for sure is the cushioning and materials in the $90 chairs are much worse compared to SecretLab. Maybe same OEM but one is definitely an inferior product.
My friend's cheap gaming chair from Qoo10 can feel the spring inserting into his ass after a few months of use.
yamashita
Moderator
Moderator
$howm3h0w
Hi all thank you so much, really appreciate them as always.
Really decided to go for the behemoth & really is the best out of the best.
Thank you
