Xiaomi Mi A3
BluePill
Why some India website says Feb 20th A4 is already released.
Sent from Xiaomi REDMI NOTE 10 using GAGT
Can't be la. At least 10 month cycle la.
Anyway this mi a series they don't make much money. I doubt it will continue for long.
carboy00
Cant find anything other than from India websites too
Top results somemore on google search somemore.
Their forked tongue dua pao sian is just amazing.
We will need to wait for Xiaomi to launch a selfie-centric model in China before we see it coming out as a Mi A device. Mi A1 was Mi 5X, Mi A2 was Mi 6X and Mi A3 was Mi CC9e. The choice for Mi A3 was questionable at best, since they could have easily chose the Mi CC9 instead, yet they choose to launch it as Mi 9 Lite.
I really hope something can be done about the software update situation, I hardly see a smooth rollout of security patches and major Android version updates. Monthly security patches always introduce more bugs than fixing them, major Android version updates cause bootloop (Mi A2 Lite Android 10) if not cause something major to not work properly (Mi A2 Android 10 Wi-Fi issue and Mi A3 Android 10 Fingerprint sensor issue). :s22:
BluePill
:s22:
I prefer the smaller form factor tbh. But the 720p a bit Sian. But I using as a second phone to pcwx only.
xonix
Anybody using gcam on this phone ? How's the hdr processing speed ?
Apex
Not sure what happened to my A3.
I notice that when I charge the device it would get WARM but the battery power never increase. The percentage remains the same.
I change to new cable and charger same issue. I need to restart the phone and reconnect the USB cable than the battery will get a charged.
Not sure if this is a Software or Xiaomi bug or really a hardware issue.
treeskull
Restart phone?
Sent from 你是我的小啊小苹果儿怎么爱你都不嫌多红红的小脸儿温暖我的心窝点亮我生命的火火火火火火 using GAGT
aucheukyan
is your charger PD or Quickcharge?
Sent from Samsung SM-G9700 using GAGT
Apex
Restart phone?
Hold the power and select restart from the menu. That is what i mean
Techno Pride
I dont wanna upgrade to Android 10. How do I skip the msg?
Will there still be monthly updates to Android 9?
treeskull
Got new update
a4973
Hi, my A3 appears to be stuck in 1 Mar 2020 in Settings>Security>Google Play system update. When check for update it always fails. Anyone with this issue? Thanks
kevin301
Finally updated to Android 10 late last night.
Happy to receive the update at long last!
Mancunian2
Will there will an A4 coming out this year?
Still using A2 lite as 2nd phone,
Want to continue using Android One
