Redmi Note 8
Pocoyoz
Recd my set liao
Have some good signs its local set
Its sealed and pre installed with singtel dash, lazada and hi card apps.....have yet to try the nfc
Sent from Samsung SM-G985F using GAGT
moi from xiaomiofficialstore.sg dont have dash, singtel app :s22:
Pocoyoz
I have this suspicion that that this store maybe run by the same group of folks that runs the Mi Official Global Store on Shopee as well. The products available and the prices are almost the same. :s11:
Posted from PCWX using Mi A2 Lake Blue
Xiaomi Singapore fb got post links to shopee Xiaomi Official Store Global before.
:spin::spin:
Audiology93
Does it comes with pre installed app like lazada or singtel dash?
Nfc works?
Lazada, yes. Can't rmb if there's dash.
Thanks for the feedback, may I ask if you have done a check on your unit and is the delivery address Singapore?
https://www.mi.com/global/shield#imei_en
Yes delivery address is Singapore. Posted it quite a few pages back.
https://forums.hardwarezone.com.sg/125410570-post1543.html
Sent from Samsung SM-N950F using GAGT
carboy00
Thanks for your help! Appreciate it. :)
Posted from PCWX using Redmi Note 8 Pro Ocean Blue
wongminmin
is this seller....legit for local warranty?
i don't rem buying any local rmn 8 tho....:s22:
carboy00
:s22:
Yup, bought my Redmi Note 8 Pro and a Mi 9T for family member from them. All verified to have delivery address as Singapore.
jc777
Did your phone boxes have the EIN and IMDA stickers?
carboy00
Nope. I believe these units come straight from a warehouse in China and does not go through EIN distributor, hence no EIN sticker. Do they still put IMDA stickers even on EIN units now?
jc777
Yes. Saw boxes with both EIN and IMDA stickers.
carboy00
2 and a half months on, I really liked the phone. I didn't see any stutters he mentioned on my unit. Camera can be better (still using my Pocophone F1 as my main shooter), battery life is same if not slightly better than my Pocophone. Having NFC is a huge plus.
Now only issue is that updates are taking forever to arrive, been more than a week since the Android 10 update has been out as beta Stable and until now no news.
Baraka
Why my NFC function not working?
I tried to use for payment. The icon on the notification lights up, but the card reader is not detecting.
GoodBetterBest
You applied the latest update 11.0.6.0 ? I did. It broke the NFC. I had to hard reset the phone to get it back.
Just to be sure, you can test at home. Get a working ezlink card, turn on NFC and place the card behind the phone (top portion). If your volume is up, you will hear a sound. That means your hw is working and you should troubleshoot your software.
carboy00
how to get the cheapest note 8 on shopee?
Official Xiaomi store on Lazada selling Note 8 64GB at 199 from 12midnight to 2am on 27th. Note 8 Pro 128GB at 299 at same time.
eting72
noted with thx
Sent from OnePlus HD1900 using GAGT
Aizenhart
Can the ShareMe app on the Redmi note 8 transfer/migrate most of my files and apps from my old Redmi note 3 pro?
I have never tried using ShareMe before.
