gregory_choo
- Nov 7, 2007
Can anyone share the Facebook group link on TV box discussion
tv box sg
Guys using Mi Box S, and had some of the apps like B**TV and Ty****.
But for some reasons the videos loaded is buffering? The MiBox S runs on wifi, and checked the speed using some app from Playstore and it getting about 50mbps download and upload speeds. Is this comparative slow network?
But the tv when its own internal Youtube seems to be fine and loading with no buffering :/
Are there any other settings I can twerk?
Which android boxes are good for movies and also USA/Korean/Taiwan shows?
Any good ones to recommend?
Buy a good box, Google... at least 4G RAM/64G, 4K
Then go TV Box check for the apps to watch
Or U tube have some videos
Non tech people buy those box with pre installed apps which they download also.
I think it more on the app to see movies.
Not so much on Android box
Most of the box out there should work well with a movies app
What android box do you both use?
Mecool KM9 Pro 4GB/32GB
Is this good performance? And easy to use?
How much? Where to buy?
Indian
TVB/China/Korea
All ok?
Where to buy NVidia Shield TV Pro, preferably with local warranty?
I think mi box is safe bet, X96 etc. Just get a below $100 box and play with it. Those $200+++ are for gaming etc.
https://www.bestinsingapore.co/best-android-tv-boxes-singapore/
I don’t own box, can’t afford. I still recommend 4G/64G as 2G is slow.
What programs do you usually watch with this box?
Undecided between evpad plus or unblock tech box
Need something that can watch malaysia live tv channels too
Anty advise
Anty advise
We used paid app to view.
You can search around in Shopee website
yeah I got it from Shopee too!! The cheapest I saw is this one - https://shopee.sg/【G-M】MECOOL-KM9-P...oth-4.0-Voice-Remote-C-i.135251631.7517732663We used paid app to view.
Is it good?
