noob ryzen start off
wtfwfs
greetings...
am going for a ryzen build after sticking to intel for so long...
just itching for a Mini ITX build so would like to seek gurus for feedback.
maybe for simple gaming/ video rendering
cpu - RYZEN 2600
mobo - ASUS ROG STRIX B450-I
gpu - ASUS Phoenix GeForce® GTX 1660 OC edition 6GB GDDR5
psu - CORSAIR SFX 450 FULL MODULAR
ram - KLEVV 8GB X 2 3600MHZ
that should the main rig.
for case im thinking of the silverstone SG13 with BeQuiet shadow rock lowprofile cooler.
please do input.
thank you
gld998
greetings...
cpu - RYZEN 2600
please do input.
thank you
Get this instead.
mobo - MSI B450I GAMING PLUS AC
shadey
If say I wanna push my 2600 to 4ghz?
3000 series are better overclockers. But even then, most testing shows that just leaving the CPU to boost itself is better. Overclocking will boost all-core benchmarks at the expense of heat and potential degradation from too high voltages, but not benefit single threaded loads like games.
Make sure you install the Ryzen drivers and select the Ryzen Balanced power plan.
Phen8210
actually the overclock potential on ryzen is quite limited.. if u lucky u can oc to the advertised boost speeds.
Also, u either get 1600 AF then get 4000 in future or 3600 and settle down... just my two cents for your money worth.
xdcphrx
i think if you get a bigger PSU unit for just a $10-20 dollars more, its safer. And maybe even re-use it for next upgrade if you want to. I'd recommend 3600.
dzpliu
If just for gaming, go for intel, 96KF would do great.
2600 is really not good enough right now unfortunately, if you really like AMD, go 3500X for gaming, 3600/3700X for both. Zen2 cpu mostly can't overclock much.
If you need to do video related, sometimes depending on your task, it might use more of GPU(da vinci studio) than CPU. And, ya go for 1660 Super instead.
My ITX build: Ryzen 5 3600, RX 5600 XT, 8GB X2 hyperX, EVGA GM550, Nuovolo Steck case.
wtfwfs
thank you all for the feedback...
currently my current serves the purpose but i itching to build a smaller form factor...
should i break my system to sell for parts or just keep as reselling wont get much value?
Cpu is delided and resealed with liquid metal overclocked to 4.6ghz on 1.25v
full load temps @ 80 degree max (AIDA64)
CPU: Intel I7 4770K "delided"
MOBO: Asrock H97m Pro 4
RAM: 4 X 4GB Corsair Vengeance
GPU: Gigabyte Geforce GTX 1060 G1 gaming 6G
PSU: Cooler Master MWE Gold 550 Full Modular PSU (bought on dec 2019)
CASE: Tecware Nexus M mATX Dual Fan Tempered Glass Gaming Casing (bought on dec 2019)
CPU COOLER:
- Cooler Master Hyper 212 RGB Black Edition (bought on dec 2019)
- x2 Bequiet Silent Wing 120mm high speed (bought on dec 2019)
CHASSIS COOLING:
- x2 CORSAIR AF Series AF120 White LED (bought on dec 2019)
im still coping well with games like cod and stuff but just that i want to downsize my setup.
wtfwfs
after all the feedbacks!
i should just pump abit more cash to put on the ryzen 3600.
ive seen those open concept sort of cases/ stands...
wanna do actually like those.
one slim cooler (noctua)
one fan gpu
xonix
Looks nice but later all the dust collected, you will have headache.
karlgantry
Quite headache -just checked which lists all supported CPU's, and the Ryzen Class do not appear there, so be careful.
