Redmi Note 8
ekardo
I will wait patiently for the official release..no push/pull factor to move to andriod 10 anyway,,
hellscream
All back to be good with the new 11.0.1
You applied the latest update 11.0.6.0 ? I did. It broke the NFC. I had to hard reset the phone to get it back.
Just to be sure, you can test at home. Get a working ezlink card, turn on NFC and place the card behind the phone (top portion). If your volume is up, you will hear a sound. That means your hw is working and you should troubleshoot your software.
huatson
Got the redmi note 8 ram 4gb, 64gb from Lazada sales from xiaomi online (Lazada mall), upon checking the imei online, the delivery address is **! Anyone know which country is that huh?
wongminmin
cambodia...
cscs3
No. I think Xiaomi is confusing on the numbers.
11.0.1 is the latest and running on Android 10 while 11.0.6 is on Android 9.
Xiaomi is always confusing in this area. Sometime it depend when they start to integrate that particular Miui version into new Android version.
Pocoyoz
11.0.1 QGG Android Q
11.0.6 PGG android P?
Found out moi still using 10.4.1 :eek:
Sent from Amazon using GAGT
davidwong
My note 8 pro arrived today and the address from the website said it’s delivered to Singapore and I have mi receipt does it mean the phone is able to warranty with xiaomi Sg @funan?
I know nothing Beats going there to ask personally with the phone and receipt but prior me going to that, think see got other bro have similar experience
carboy00
My note 8 pro arrived today and the address from the website said it*********s delivered to Singapore and I have mi receipt does it mean the phone is able to warranty with xiaomi Sg @funan?
Delivery address Singapore should be good enough indication can claim from Funan service centre liao.
Posted from PCWX using POCOPHONE F1 Rosso Red
davidwong
Hopefully have warranty then it’s will be very good deal for 268 6/128 Note 8 pro
i1magic
Heard that India version of Redmi Note 8 Pro comes with dual SIM + micro SD adapter.
Can anybody confirm? Anybody using that now?
Any Xiaomi phone with cpu equal to or better than Helio G90T that can support dual SIM + micro SD card?
GoodBetterBest
Is your RMN8 Type Port a bit shaky when you charge ? It can move a bit. My original cable fit tight but shakes very slightly. I have another cable which has a gap after inserting and it shakes more.
Pocoyoz
indian Redmi Note 8 Pro dual sim+ microsd but no nfc
redmi note 9s loh 720G cpu slightly better than G90T, but gpu lose a bit
