Aircon issue
bendi85
Hi any recommended aircon workshop?
Between mark cool and tomika, which one u all prefer?
Or is there other better ones?
I stay east side.
SuperSprint
aircon i go New luck aircon, the old uncle will help check and on the spot tell u the problem
he is so call the god of aircon, located at autobay at east side
bendi85
I see. My aircon not very cold especially on hot weather.
LouisSaha
North side can try sg garage.
They operate in yishun and amk.
They quite good with aircon
EJB
It largely depends on the fix required.
My old Vios compressor died, so a simple change at any workshop would do.
Infinite
I just went to kim aircon today. The boss seems friendly and workers quite knowledgeable. Overall service is good.
nice, I'm having the same issue too. At night it works fine, at noon the cold air is near gone.
what was the issue and how much were you quoted?
Stallone
thanks.. now to decide if I should fix it in sg, jb or to just bear with it till it gradually spoil for good :s13:
wad's ur ride model?
unless u only drive at night, suggest u get it fixed
likely clutch/control valve tt needs change, wont cost much
Infinite
suzuki swift.. probably will gather a few quotes first, anw recently the car is spending most of its time in the carpark
sunsetbay
Moderator
Moderator
my aircon suddenly down~ was working perfectly on fri, sat didn't drive, park under the hot sun~ can hear the compressor cut in when turn on aircon, air was slightly cool but still stuffy~ what's the likely fault~? :(
bh10101
quickly sent in for servicing... before operation stop for 1 mth.. :s12::s12:
bh10101
very grey area.. you need to verify whether your workshop is opened.
I think AD mgmt are still in discussion/verifying, or at least I know mine will get to know at today 2pm.
https://covid.gobusiness.gov.sg/essentialservices/others/
6. Vehicle recovery and repair services
a. For emergency vehicle services only, no vehicle grooming.
car workshop not affected leh~ those car grooming, detailing will be closed~
