Dell Monitors Help
Matrock5
Hi im considering between the Dell U2719DC, Dell U2720Q and the P2719H
i surf, watch movies do adobe work and office work. Anyone can advise?
batniss
if you got budget, go for the most expensive one.
Matrock5
i am very tempted on the U2720Q but 4k will make e text and icons small erm.... not sure if i should spent the amount on the 4k monitor. but when i chat with the dell agent online they gave a very good quotation with discount.
carlover76
I also want to get a New Monitor for my home since I am working from home for this one month, I wanted to get the U2419H initially but now looking at the Prism+ X315 and the Dell U2719D.
Comparing Prism+ X315 is for gaming and using VA Panel versus the IPS Panel on the Dell so not sure which to choose.
Matrock5
Yes yes me too for this one month and prob after that as well to play switch etc on the monitor. I am not keen on Prism as i have friends who bought it but broke down after a few month or less den a year.
I have been using dell monitors and found them to be ok and the warranty, one to one exchange was good too. i chatted with the Dell agent and gotten the quote for both U2719DC and U2720Q the price difference between them are just $40.
carlover76
Oh I see, guess I will stick with Dell cos I dun feel quite like the curved screen and the VA Panel though.
Have you consider getting the Dell from Local Distributor on Lazada or Qoo10 which will be cheaper? How much is the price you get direct from Dell?
LIN_JOEL
$50 off RRP?
tigerwoods
IPS always the first choice.
purpleberry
How much of a discount did you receive? Sometimes they can be quite flexible. Can try bargaining for 5years warranty also.
carlover76
Opps. price increase liao...
That time I ask for online quotation is $758.
But managed to get a better deal offline :)
Oh, they give you the quotation of $758 still intact then it is really worth to get it.
You mean you just write in and ask for the price?
Matrock5
I am getting it directly from Dell online if possible. U can have a chat with the agent they will ask you some questions and give u a quote.
carlover76
I see but I know the lead time might be longer if you get from Dell compared to local distributor, right?
Matrock5
Warranty wise i guess it is pretty much fix for discount it was quite good as i gave the details of my uncle's email as he is from edu sector.
hafiz116
I bought the 32” 4K monitor a few months back. I have to say when it comes to monitors especially for work Dell is the way to go.
The 4K monitor only has a refresh rate of 60Hz so not that great for gaming I’m told. I’m using it for the games I have and I couldn’t be happier :)
