Tonight 2359 deadline?
.... How to speed wise you find? Same as normal M1 speed?
Just now messaged cso, they say extend to 30 Apr. The T&C also state 30 Apr
Cant find this info. Got link?
Don't know whether I should keep my legacy Uno plan since they said they might be giving Uno plan users some perks
Or should i terminate my Uno plan and keep my new Lite sim?
The general consensus and benchmarks throughout the industry consistently shows Starhub being superior to M1.
Any idea if they will be migrating my Uno plan from Starhub to M1? Just checked and it's still under Starhub.
Still starhub lehI got the email, same as you. � this is probably the migration liao, it says data service affected, pls restart phone if no data
Can u access the Internet? I restarted my phone twice. Still no Internet access. Using APN myrepublic.Still starhub leh
Sent from Amazon using GAGT
Working for me. Still on starhub network.Can u access the Internet? I restarted my phone twice. Still no Internet access. Using APN myrepublic.
Jialat. Going to work now.
No dataCan u access the Internet? I restarted my phone twice. Still no Internet access. Using APN myrepublic.
Still starhub leh
No data
I have just checked in the morning, yes sadly still on StarHub mobile Network.Can u access the Internet? I restarted my phone twice. Still no Internet access. Using APN myrepublic.
Working now.
Just received MR sim that I signed up last week for the $10 plan. An sms indicates that the porting will be done (from Giga (SH)) tonight. Activating the new sim no problem. Signal strengths and speeds of Giga and MR appeared similar, at least at my location.
What was the caused? their backend issue or ur phone side? Thanks
So far the porting went smoothly. But one problem ...
With VoLTE on and making a voice call, it shows an error "server unreachable". Turn off the VoLTE then no problem of making voice calls.
Called their technical hotline and escalated the issue. Hope they can resolve it.
Are you still having no data right now? My APN is set as shwap, try if it works for you. If not try, removing the sim and re-inserting the SIM card.
