OnePunch!!
- Apr 20, 2019
Maybe fire and employ more hahahhah cut cost
But they did get some funding recently.
Why is Vivobee's plan confusing? The unlimited plan is $1 for 99 month.Then must add on at least $5 every month right?
For circles life voice call, I frequently experience interference.
VoLTE is technically already out on Circles but I am struggling to get it to work for my main line, my Flexi line VoLTE works fine. Put my main line SIM into 3 different phones (all of which VoLTE on TPG works), just doesn't work. Contacted them, they insisted my SIM card is fine and VoLTE is enabled.
Posted from PCWX using Redmi Note 8 Pro Ocean Blue
I would say, in terms of MVNO ranking, this is probably the case
1) Circles
2) GRID
3) RedOne
4) MyRepublic
5) VIVIFI
6) Zero1
7) CMLink (for now)
Unknown:
Vivobee (really hard to gauge as their plans aren't aimed for locals, plus their plans is so darn confusing I'm not even sure if the foreigners will get it or not)
Reason why GRID is so high is because it has the strong trunk communication as core and it's popularity is quite high compared to other SingTel MVNOs, especially amongst younger population. I've seen a few friends on GRID while almost nobody know the existence of Zero1/VIVIFI. RedOne has Malaysian side as backing so it's not that bad. China Mobile CMLink also has their China backing so it may not be that bad too, but unconfirmed because it is too new.
MyRepublic probably have to use their broadband as anchor and the mobile as side project with minimal profitability if any.
Zero1 plagued with billing issues, therefore there's a much higher chance of becoming another Zero Mobile.
VIVIFI may be able to save themselves with their $8.80 Lite plan, as it's a good deal for those that need lots of talktime and not much data. Recommended that plan to a few of my friends for their parents already, even though I'm not affiliated with them.
I am surprised that grid is popular, although I know it will be hard for grid to collapse as it is a JV between two big players. I suppose the points system is attractive to many youths.
I will disagree about Zero1 and Vivifi though. I think for its flaws, Zero1 will ironically survive longer than Vivifi, because of the unlimited gimmick and its $9.90/$13.90 plan. Vivifi doesn't have much attractions unless the subscriber has a big family to share data or old folks that don't use much data. But then again, the older folks all use FB and whatsapp nowadays so more data might be preferred.
Hi guys... My CL CIS plan has ended and now i'm paying $28/mth... i want to enjoy the $18/mth again so the only way is to port out to another telco then port back in with new CIS sign up right?
which telco would you guys recommend? I'm thinking of porting out for 1-2 mths then port back CL again for the new CIS. is it possible?
It is not really "Unlimited". There is a max amount of so called Fair Usage Limit before your speed is throttled.
My understanding is the Roll Over will extend the Fair Usage to another higher limit.
I don't think it is just the points system actually. The 40GB at $24.90 is pretty good, especially if you compare it against the competition. The additional 1GB Malaysia Roaming makes it even more attractive too.
M1 gives 30GB for $25/mth, and that excludes Caller ID. Even if accounting the $5/mth disc that pop up sometimes, it's still lesser value.
StarHub requires a 12 month contract for $25/mth and give 25GB + UWD. No contract only have 15GB + UWD, which is flat out no go for many.
SingTel requires a 12 months contract for $25/mth and give 30GB. Still lesser value than GRID, unless VoLTE and WiFi Calling is "mandatory" for you.
There's no real competition for them, unless you take into account multiple line set up, like MyRepublic $10 6GB / Giga $10 5GB / Vivifi $8.80 3GB / RedONE $8 3GB / Circles $5 2GB / Zero1 $9.90-13.90 1GB + TPG $10 50GB plan, which may be better value but won't be as hassle free and coverage issues that TPG still faces.
Anyone got a good promo code for circles?
best i found so far is SGDTIPSCL, free unlimited data for 6 months on $18 plan
Starhub base plan for 12 months SIM-only is 25GB for $25
ADD-ON 50GB @ $20. Worry-Free Data.
Aka unlimited after 75GB.
Can also take up No Contract for 15GB @ $25.
Total 65GB @ $45 till unlimited.
M1 offers 30GB @ $25
+10GB @ $5
+50GB @ $10
+150GB @ $20
Total 180GB @ $45 (take note Caller-ID is only free for 3/6 months)
Circles.Life 20GB @ $28 (Port-In @ $18)
Free Unlimited Data for 12 months
Total 100GB to Unlimited Data.
Able to Rollover up to 300GB for using less than the allocated.
+$2 for unlimited incoming calls.
The promo code is still active
TLOFFER2020
Is it trottled after 20gbTLOFFER2020
I also got another code for Cis 100gb plus free rollover for $18
Dunno which better
Dunno which better
Is it possible to get $18 registration fee waived for the $5 plan?
