ITX Cases
hg2
Ghost Black - negative airflow working well!
Streacom Silver - poorer airflow +5degree vs Ghost
All with AIO OC'ed, reddot weather to hot for ITX ambient fan cooling a Ryzen9 or i9 CPUs....
Going to try NZXT H1, after **... if i can find one with 3yrs local warranty....
taytehni
Anyone here tried those copies of the S1 on taobao before? Looking to try out one from WDEAN DORA in the future for my next upgrade. Currently ordered a Jonsbo A4 V1.1 and waiting for it to arrive for a friend's build.
hg2
Suggest u join his wechat first, rumours many many unfulfilled backlogs due to covid-19, he was screwed by the factory...idk which... WDEAN price just top up a bit can get genuine one from amazon.... just my 2cents view.
gld998
WDEAN DORA
Jonsbo A4 V1.1
looks good!:)
taytehni
thanks for the heads up, will do so and see how it goes. From what I see, its like 269usd on amazon vs 160~180sgd not factoring in any shipping costs. thats quite a big difference in my opinion.
edit: i guess you are referring to the D1S model instead of the R1S model. do you know the difference between them?
hg2
Original has serial number and resale values.
The seller has made a video, u can find the file "R1S和D1S的区别" once u join the wechat. Usually the difference is the materials, internal precisions, and paints.
If on budget, look for kevcases, they have the beginner white model for 100SGD on saltedfish. But u need to source own PCI cables.
flame2000
Where u bought the Jonsbo A4 v1.1 from?
I am considering this case too but too many choices.
gld998
can share link to buy? I am interested. Reddit links expired. :(
hg2
100 SGD beginner version
https://item.taobao.com/item.htm?spm=a1z10.3-c.w4002-3959728068.14.7577fd16bToEBU&id=615655235485
200 SGD black version
https://item.taobao.com/item.htm?sp...Qwuz6L&id=600836353624&ns=1&abbucket=8#detail
400 SGD RED SUPREME (Been eyeing this for very long....)
https://item.taobao.com/item.htm?sp...Qwuz6L&id=589023907385&ns=1&abbucket=8#detail
Note : from the price you can tell it doesn't come with PCIE extension cable (90 SGD)
gld998
PCIE Cable need SGD 90?!:eek:
Soya_Bean
Is this the Ghost S1 replica?
hg2
Most of them I see is like 20+ only leh on TB. Might have to do with the efficiency i guess.
https://item.taobao.com/item.htm?sp...sT0P1&id=611617890453&ns=1&abbucket=12#detail
Don't need to get those over price Phanteks/3M...they cannot go beyond PCIE3.0.
ADT riser ~20 SGD is good enough for all GTX cards. if u happend to use 570X and RX5700, set the bios to PCIE3.
Clones, with varying qualities and finishing... u pay what u get....
