- Mar 22, 2011
Backlight bleed is characterized as light leaking around the edges or corners of an LCD display. This is due to the way these displays work; they use a light behind the panel that faces the display. Backlight bleeding is simply some of the backlight leaking through.
The Redmi Note 9S has an IPS LCD screen display.
