MyRepublic Mobile discussion thread
Yihaoong
I purposely burst the data to tell you all. Not many say thanks leh lol
Anyway I still have my TPG, CMLink, M1 Unlimited and Giga to use.
"that is the throttled speed once allowable date is consumed 384 kbs up to 1.2 mbps max" - Annica, MyRepublic support
Sumimasen
Those alr received the simcard name izzit M1?
Can't see MR.
I am using dual SIM now is seeing M1 and Tpg.
Jurong640
Do I have to setup anything under the setting?
As there is no special instructions on setting.
Normally it will automatically set up once you insert the SIM. If your phone fails to register, go to your mobile network settings and set apn as MyRepublic.
mosmos
High Honorary Member
Apn should be sunsurf for those after 31 march signup
I tried creating apn to myrepublic, also works, not sure will it connect to starhub
Sumimasen
Ya mine is sunsurf mobile.
So can just leave it as it is dun do anything?
Jurong640
I don't think so, the SIM card would probably be set to connect to 52503(SGP-M1) instead of 52505(starhub)
kenzio8
Does anyone know if Nokia 3310 4G, can be used on this MR network?
I’m aware that 3310 does not support volte.
Thanks.
lohsenglte
Thanks.
Nokia 3310 doesn't have 4G variant. It is only 3G for the new model.
Yes, the 3310 3G supports MyRepublic network. M1 and StarHub do have 3G service.
Sumimasen
Wah the hp feels hot under M1.
After one month wanna port to vivifi Singtel try.
Sumimasen
The most u paid the full month subscription.
From MR support page it didn't state any minimum subscription period.
